Hi!
I'm having a small problem with my intel compiler i just downloaded and installed on my machine using VS2010 SP1 (on Windows 7 & Intel Composer XE2013 ).
as mentioned in the subject the compiler has difficulties in finding the required lib for the regex. i added the additional directories under project properties VC++ directories & under linker -> general -> additional lib. directories. the funny thing is that with the MS visual studio compiler it works, just when i switch to Intel C++ compiler it does not.
is it probably working with an older version of the boost library? which one?
Thks,
Elmar
below the last lines of the output window.
1> Loaded msvcprtd.lib(MSVCP100D.dll)
1> Found __NULL_IMPORT_DESCRIPTOR
1> Referenced in msvcprtd.lib(MSVCP100D.dll)
1> Found MSVCP100D_NULL_THUNK_DATA
1>LINK : fatal error LNK1104: cannot open file 'libboost_regex-iw-mt-gd-1_51.lib'
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:00.76
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
