Intel® C++ Compiler
Intel Fortran 9.0 debug problems
khenemura
I'm using the intel fortran 9 compiler and have some problems.
When I debug variables from a module, the debugger shows weird data in the watch window
Also when I debug allocated arrays like:
type
(RetDat), allocatable :: SteerPar(:)
Type RetDat
Real :: Tlen
Real :: Ad_mass(6,6)
Real :: Kdata(36,max_conv)
Real, pointer :: udata(:,:)
Integer :: nk(36)
Integer :: nu
End type
The debuggers shows also weird data. (only when the struct contains pointers btw)
Are this known problems?? And how can I solve them?
Everything works fine with the"Compaq Visual Fortan6.6 compiler"
I've ported a program from CVF to IVF
Thanks in advance!
Mark
khenemura
I already know the problem
In the module I use
!DEC$ATTRIBUTES DLLEXPORT :: my_variable
Somehow the debugger cant handle it. Quite anoying
