Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Intel Parallel Studio XE 2020 update 1 macOS, command line option with symlinks issue
I installed the Intel Parallel Studio XE 2020 Update 1 on my macOS (Catalina/10.15.5) and chose only the command line option and not the Xcode integration.
I hoped that I can manually use intel compilers when I need them and from a terminal session, by running `source <install_dir>/bin/compilervars.sh intel64`.
But, after installation, it automatically creates symlinks to /usr/local/bin, where all the compilers are on my PATH.
Is there a way to prevent this behavior except manually removing all the created symlinks?
Highlighted
Re:Intel Parallel Studio XE 2020 update 1 macOS, c...
Ideally, sourcing the compilers with script file (like you mentioned) should place the compilers in path and the global behavior is not expected.
I shall escalate this case to the concerned team. Thanks for reporting the issue.
--Rahul
Highlighted
Do you have another system with older macOS (e.g. Catalina/10.15.1) to try and see if the problem still persists?
Highlighted
Re: Re:Intel Parallel Studio XE 2020 update 1 macOS, c...
No, I do not.
Currently, I resolved the issue by modifying the intel linking script
compilers_and_libraries_2020.1.216/mac/link_install.sh
and removing all the created links in
/usr/local/bin
by
# remove all links
COMPXE_RMLINKS() {
    PRINT "COMPXE_RMLINKS()"
    if [ ${TARGET} == "mac" ]; then
        # remove links for binary and non-env script program files
        for THIS_FILE in $INTEL_PROGRAM_FILES_LIST; do
            if [ -e "$ROOT_DIR"/usr/local/bin/$THIS_FILE ]; then
                rm $RM_OPTIONS "$ROOT_DIR"/usr/local/bin/$THIS_FILE 2>/dev/null
            fi
            if [ -e "$ROOT_DIR"/usr/local/bin/$THIS_FILE-$VERSION ]; then
                rm $RM_OPTIONS "$ROOT_DIR"/usr/local/bin/$THIS_FILE-$VERSION 2>/dev/null
            fi
            if [ -e "$ROOT_DIR"/usr/local/bin/$THIS_FILE-$VERSION.$VERSION_UPDATE.$PACKAGE_NUM ]; then
                rm $RM_OPTIONS "$ROOT_DIR"/usr/local/bin/$THIS_FILE-$VERSION.$VERSION_UPDATE.$PACKAGE_NUM 2>/dev/null
            fi
        done
    fi
The other major problem/issue is reported before:
https://community.intel.com/t5/Intel-C-Compiler/catastrophic-error-Cannot-open-source-file-quot-stdi...
The same thing is happening here. It is simply failing on `hello.c` test case.
#include <stdio.h>
int main() {
   // printf() displays the string inside quotation
   printf("Hello, World!");
   return 0;
>> icc hello.c
hello.c(1): catastrophic error: cannot open source file "stdio.h"
  #include <stdio.h>
compilation aborted for hello.c (code 4)
