Intel® C++ Compiler
7956 Discussions
Intel Parallel Studio XE 2020 update 2 macOS Catalina 10.15.6
yaf
The reported issue XE-2020-update-1-macOS has not been resolved in the new update, yet another issue is happening.
Compiling the code,
#include <iostream>
#include <vector>
int main()
	std::vector<int> a(10, 0);
on macOS Catalina 10.15.6 with Intel Parallel Studio XE 2020 update 2 `C++` compiler fails with the below error messages,
In file included from /Library/Developer/CommandLineTools/usr/include/c++/v1/algorithm(640),
                 from /Library/Developer/CommandLineTools/usr/include/c++/v1/__string(57),
                 from /Library/Developer/CommandLineTools/usr/include/c++/v1/string_view(175),
                 from /Library/Developer/CommandLineTools/usr/include/c++/v1/string(504),
                 from /Library/Developer/CommandLineTools/usr/include/c++/v1/__locale(14),
                 from /Library/Developer/CommandLineTools/usr/include/c++/v1/ios(215),
                 from /Library/Developer/CommandLineTools/usr/include/c++/v1/iostream(37),
                 from vector.cpp(1):
/Library/Developer/CommandLineTools/usr/include/c++/v1/type_traits(903): error: function call is not allowed in a constant expression
      __is_function(_Tp)
                 from vector.cpp(1):
/Library/Developer/CommandLineTools/usr/include/c++/v1/type_traits(903): error: type name is not allowed
      __is_function(_Tp)
                 from vector.cpp(1):
/Library/Developer/CommandLineTools/usr/include/c++/v1/type_traits(2808): error: __libcpp_is_constructible is not a template
      : public __libcpp_is_constructible<_Tp, _Args...>::type {};
                 from vector.cpp(1):
/Library/Developer/CommandLineTools/usr/include/c++/v1/type_traits(2808): error: not a class or struct name
The full error message is in the attached file. Is there any idea or hint on this issue?
yaf
The only solution I found to this issue is to downgrade my mac command-line tools to version 11.5,
Command Line Tools for Xcode 11.5
Any other of the 12 version releases will break.
AbhishekD_Intel
Thank you for reporting this issue, we are forwarding this issue to the concerned team.
Warm Regards,
Abhishek
Viet_H_Intel
It's not recommended to use OS or Xcode versions that released after the compiler released built date because those versions couldn't be validated by the compiler at that time.
yaf
Thanks for your recommendation.
I got my Mac recently (in the last month), and downgrading the macOS was not an option to just make it work with the Intel compilers.
Viet_H_Intel
This issue has been resolved and we will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
