Intel® C++ Compiler
Intel Software Manager crashes
Michael_B_13
I'm using Parallel Studio 2015 on an Ubuntu 14.04 machine. It worked fine for about one month, then the ISM crashed during an update. When I try to open it I get now:
./ism
Intel(R) Software Manager startup error. Please see /tmp/intel.ism.XXX.error.log for details.
The file mentioned above only contains:
/bin/bash: line 1:   793 Segmentation fault      (core dumped) /opt/intel/ism/bin/intel64/ismcore 2> /tmp/intel.ism.XXX.error.log 1>&2
Thanks for all help!
Hubert_H_Intel
Michael,
Uninstall ISM (opt/intel/ism/uninstall.sh) and restart the Parallel Studio XE 2015 installer again. This will install the ISM coming with the package again. After successful installation you can check ISM if it works correctly.
Regards, Hubert.
Hubert_H_Intel
Michael,
Regards, Hubert.
Michael_B_13
Thanks Hubert,
now it starts, but when I try to click on "Update" for the Composer he displays "Getting list of products" and shows the "Update"-Button some seconds later again without doing anything else.
Hubert_H_Intel
Michael,
Do you mean the 'Update' inside ISM? Did you restart the Parallel Studio installer outside ISM?
Hubert.
Michael_B_13
Yes I meant the Update Button after each possible update within the ISM GUI. One hour later everything worked fine. Perhaps there was a connection error to the server. I think the problem is solved now. Thanks.
