Intel® C++ Compiler
Intel c++ compiler error with pybind11 using -std=c++17
Soprana__Arthur
I am getting a compile error when using the Intel c++ compiler (ICC - 19.0.0.046 20180317) when compiling a simple code, basically importing pybind11 with the option -std=c++17. The error log is very large, but starts as follows
In file included from /home/soprano/work/pybind11/include/pybind11/cast.h(16),
                 from /home/soprano/work/pybind11/include/pybind11/attr.h(13),
                 from /home/soprano/work/pybind11/include/pybind11/pybind11.h(43),
                 from test.cpp(1):
/home/soprano/work/pybind11/include/pybind11/detail/internals.h(175): error: a constexpr function cannot have a parameter of nonliteral type "std::__exception_ptr::exception_ptr"
              [](std::exception_ptr p) -> void {
/home/soprano/work/pybind11/include/pybind11/cast.h(2078): error: no instance of overloaded function "pybind11::detail::collect_arguments" matches the argument list
            argument types are: (const char *const)
      return detail::collect_arguments<policy>(std::forward<Args>(args)...).call(derived().ptr());
/home/soprano/work/pybind11/include/pybind11/cast.h(2064): note: this candidate was rejected because at least one template argument could not be deduced
  unpacking_collector<policy> collect_arguments(Args &&...args) {
/home/soprano/work/pybind11/include/pybind11/cast.h(2057): note: this candidate was rejected because at least one template argument could not be deduced
  simple_collector<policy> collect_arguments(Args &&...args) {
          detected during:
The command line call was
icpc -std=c++17 test.cpp -I/pybind11/include/path -I/python/include/path
However, if I change the option to -std=c++14 or c++11, it works fine. g++ also compiles with no problems when using the c++17 option. It seems like a compiler bug. The code used is presented below.
// test.cpp
#include <pybind11/pybind11.h>
int main(){
    return 0;
Does anyone have any idea of what this might be?
Arthur Besen Soprana
JenniferJ
I think this issue has been fixed. Please wait for 19.0 beta update. it should be available soon. Please check back on the beta thread. It should be updated when the beta update is available.
Jennifer
Soprana__Arthur
I've just tryed the update 1 for the beta release (icpc (ICC) 19.0.0.070 20180524) and now got different errors:
icpc -std=c++17 test.cpp -I/home/soprano/work/pybind11/include -I/home/soprano/miniconda3/include/python3.6m
          detected during:
            instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<const char *const &>]" at line 1322 of "/home/soprano/work/pybind11/include/pybind11/pytypes.h"
            instantiation of "bool pybind11::detail::object_api<Derived>::contains(T &&) const [with Derived=pybind11::handle, T=const char *const &]" at line 143 of "/home/soprano/work/pybind11/include/pybind11/detail/internals.h"
          detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<>]" at line 200 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h"
            argument types are: (pybind11::handle, pybind11::handle)
          detected during:
            instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::handle &, pybind11::handle &>]" at line 881 of "/home/soprano/work/pybind11/include/pybind11/pytypes.h"
            instantiation of "pybind11::str pybind11::str::format(Args &&...) const [with Args=<pybind11::handle &, pybind11::handle &>]" at line 749 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h"
            argument types are: (pybind11::handle, pybind11::handle, pybind11::none, pybind11::str)
          detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::handle, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::handle, pybind11::handle, pybind11::none, pybind11::str>]" at line 964 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h"
            argument types are: (pybind11::tuple)
          detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::tuple &>]" at line 1717 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h"
            argument types are: (pybind11::object)
          detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::object &>]" at line 1735 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h"
          detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::object>]" at line 1736 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h"
compilation aborted for test.cpp (code 2)
Viet_H_Intel
Can you please create a preprocess file for us?
$icpc test.cpp -E -std=c++17-I/home/soprano/work/pybind11/include -I/home/soprano/miniconda3/include/python3.6m
Viet
Soprana__Arthur
Sure, here it goes (see attached file).
Arthur
pfahler__lukas
Any updates on this one?
Viet_H_Intel
Have you tried 19.0 Update 5?
Soprana__Arthur
No sorry. My intel license has expired and therefore I am not able to check if it works on this version.
The error still persists.
Viet_H_Intel
For some reasons, I couldn't be able to download your preprocessed file. Can you upload it again.
Soprana__Arthur
Here it goes
Viet_H_Intel
Thanks for the preprocessed file. I've reported to our Developer. Internal tracking number is "CMPLRIL0-32248"
