In file included from /home/soprano/work/pybind11/include/pybind11/cast.h(16), from /home/soprano/work/pybind11/include/pybind11/attr.h(13), from /home/soprano/work/pybind11/include/pybind11/pybind11.h(43), from test.cpp(1): /home/soprano/work/pybind11/include/pybind11/detail/internals.h(175): error: a constexpr function cannot have a parameter of nonliteral type "std::__exception_ptr::exception_ptr" [](std::exception_ptr p) -> void { ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2078): error: no instance of overloaded function "pybind11::detail::collect_arguments" matches the argument list argument types are: (const char *const) return detail::collect_arguments<policy>(std::forward<Args>(args)...).call(derived().ptr()); ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2064): note: this candidate was rejected because at least one template argument could not be deduced unpacking_collector<policy> collect_arguments(Args &&...args) { ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2057): note: this candidate was rejected because at least one template argument could not be deduced simple_collector<policy> collect_arguments(Args &&...args) { ^ detected during:
The command line call was
icpc -std=c++17 test.cpp -I/pybind11/include/path -I/python/include/path
// test.cpp #include <pybind11/pybind11.h> int main(){ return 0; }
Does anyone have any idea of what this might be?
Arthur Besen Soprana
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
I think this issue has been fixed. Please wait for 19.0 beta update. it should be available soon. Please check back on the beta thread. It should be updated when the beta update is available.
Jennifer
I've just tryed the update 1 for the beta release (icpc (ICC) 19.0.0.070 20180524) and now got different errors:
icpc -std=c++17 test.cpp -I/home/soprano/work/pybind11/include -I/home/soprano/miniconda3/include/python3.6m /home/soprano/work/pybind11/include/pybind11/cast.h(2078): error: no instance of overloaded function "pybind11::detail::collect_arguments" matches the argument list argument types are: (const char *const) return detail::collect_arguments<policy>(std::forward<Args>(args)...).call(derived().ptr()); ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2064): note: this candidate was rejected because at least one template argument could not be deduced unpacking_collector<policy> collect_arguments(Args &&...args) { ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2057): note: this candidate was rejected because at least one template argument could not be deduced simple_collector<policy> collect_arguments(Args &&...args) { ^ detected during: instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<const char *const &>]" at line 1322 of "/home/soprano/work/pybind11/include/pybind11/pytypes.h" instantiation of "bool pybind11::detail::object_api<Derived>::contains(T &&) const [with Derived=pybind11::handle, T=const char *const &]" at line 143 of "/home/soprano/work/pybind11/include/pybind11/detail/internals.h" /home/soprano/work/pybind11/include/pybind11/cast.h(2078): error: no instance of overloaded function "pybind11::detail::collect_arguments" matches the argument list return detail::collect_arguments<policy>(std::forward<Args>(args)...).call(derived().ptr()); ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2064): note: this candidate was rejected because at least one template argument could not be deduced unpacking_collector<policy> collect_arguments(Args &&...args) { ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2057): note: this candidate was rejected because at least one template argument could not be deduced simple_collector<policy> collect_arguments(Args &&...args) { ^ detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<>]" at line 200 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h" /home/soprano/work/pybind11/include/pybind11/cast.h(2078): error: no instance of overloaded function "pybind11::detail::collect_arguments" matches the argument list argument types are: (pybind11::handle, pybind11::handle) return detail::collect_arguments<policy>(std::forward<Args>(args)...).call(derived().ptr()); ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2064): note: this candidate was rejected because at least one template argument could not be deduced unpacking_collector<policy> collect_arguments(Args &&...args) { ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2057): note: this candidate was rejected because at least one template argument could not be deduced simple_collector<policy> collect_arguments(Args &&...args) { ^ detected during: instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::handle &, pybind11::handle &>]" at line 881 of "/home/soprano/work/pybind11/include/pybind11/pytypes.h" instantiation of "pybind11::str pybind11::str::format(Args &&...) const [with Args=<pybind11::handle &, pybind11::handle &>]" at line 749 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h" /home/soprano/work/pybind11/include/pybind11/cast.h(2078): error: no instance of overloaded function "pybind11::detail::collect_arguments" matches the argument list argument types are: (pybind11::handle, pybind11::handle, pybind11::none, pybind11::str) return detail::collect_arguments<policy>(std::forward<Args>(args)...).call(derived().ptr()); ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2064): note: this candidate was rejected because at least one template argument could not be deduced unpacking_collector<policy> collect_arguments(Args &&...args) { ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2057): note: this candidate was rejected because at least one template argument could not be deduced simple_collector<policy> collect_arguments(Args &&...args) { ^ detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::handle, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::handle, pybind11::handle, pybind11::none, pybind11::str>]" at line 964 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h" /home/soprano/work/pybind11/include/pybind11/cast.h(2078): error: no instance of overloaded function "pybind11::detail::collect_arguments" matches the argument list argument types are: (pybind11::tuple) return detail::collect_arguments<policy>(std::forward<Args>(args)...).call(derived().ptr()); ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2064): note: this candidate was rejected because at least one template argument could not be deduced unpacking_collector<policy> collect_arguments(Args &&...args) { ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2057): note: this candidate was rejected because at least one template argument could not be deduced simple_collector<policy> collect_arguments(Args &&...args) { ^ detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::tuple &>]" at line 1717 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h" /home/soprano/work/pybind11/include/pybind11/cast.h(2078): error: no instance of overloaded function "pybind11::detail::collect_arguments" matches the argument list argument types are: (pybind11::object) return detail::collect_arguments<policy>(std::forward<Args>(args)...).call(derived().ptr()); ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2064): note: this candidate was rejected because at least one template argument could not be deduced unpacking_collector<policy> collect_arguments(Args &&...args) { ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2057): note: this candidate was rejected because at least one template argument could not be deduced simple_collector<policy> collect_arguments(Args &&...args) { ^ detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::object &>]" at line 1735 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h" /home/soprano/work/pybind11/include/pybind11/cast.h(2078): error: no instance of overloaded function "pybind11::detail::collect_arguments" matches the argument list argument types are: (pybind11::object) return detail::collect_arguments<policy>(std::forward<Args>(args)...).call(derived().ptr()); ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2064): note: this candidate was rejected because at least one template argument could not be deduced unpacking_collector<policy> collect_arguments(Args &&...args) { ^ /home/soprano/work/pybind11/include/pybind11/cast.h(2057): note: this candidate was rejected because at least one template argument could not be deduced simple_collector<policy> collect_arguments(Args &&...args) { ^ detected during instantiation of "pybind11::object pybind11::detail::object_api<Derived>::operator()(Args &&...) const [with Derived=pybind11::detail::accessor<pybind11::detail::accessor_policies::str_attr>, policy=pybind11::return_value_policy::automatic_reference, Args=<pybind11::object>]" at line 1736 of "/home/soprano/work/pybind11/include/pybind11/pybind11.h" compilation aborted for test.cpp (code 2)
Can you please create a preprocess file for us?
$icpc test.cpp -E -std=c++17-I/home/soprano/work/pybind11/include -I/home/soprano/miniconda3/include/python3.6m
Viet
Any updates on this one?
Have you tried 19.0 Update 5?
No sorry. My intel license has expired and therefore I am not able to check if it works on this version.
The error still persists.
For some reasons, I couldn't be able to download your preprocessed file. Can you upload it again.
Thanks for the preprocessed file. I've reported to our Developer. Internal tracking number is "CMPLRIL0-32248"
