Intel® C++ Compiler
7833 Discussions
Intel c++ compiler icx - support for Qlong-double Qpc80
GrzegorzW
Hi
I am using latest Intel compiler C++ 2022 and my application return some ULP precision errors when I use long double data type. Previously I used Intel C++ compiler 19.3 and I got expected results.
So binary compiled on in the same Visual Studio, machine,  with different compiler versions produce different results. I am using the following compiler properties for compilation:
/Qlong-double /Qpc80 -fp:strict
Is there anybody who can help me.
VarshaS_Intel
Could you please let us know the Visual Studio version you are using?
Could you please provide us with the sample reproducer code and steps to reproduce the error at our end? And also, could you please provide us with a screenshot of the expected results?
Thanks & Regards,
Varsha
GrzegorzW
Thanks for answer.
I've attached two exe files one compiled using Intel C++ compiler 19.1 (icc.exe) and Intel compiler 2022(icx.exe) in the same env MSVC 2019. You can find there as well two screen shots from output. I see errors in group of math functions that this exe is able to test. The test is official Khronos Conformance test for OpenCL API (link below). For reproduction purpose lets focus on one of them "atanh". Shortly the test calculate reference value on CPU and take results from calculation on GPU. To run this test you have to have Intel GPU driver in you environment with OpenCL support and cl_khr_fp64 extension (eg. platforms Coffee Lake, Kaby Lake, Sky Lake). From my experiments I conclude that icx ( version 2022) compiler calculate different values in case of long double data type comparing to icc compiler (version 19.01)
reproduction:
test_bruteforce.exe -w atanh -f -1
options:
( -w less input values, -f do not test fp32, -1 only scalar data types)
result:
1: atanh fp64 ....
ERROR: atanh: 35369785491456.000000 ulp error at -0x1.0000000000000p-39 (0xbd80000000000000): *-0x1.0000000002000p-39 vs. -0x1.000155588891ap-7
ERROR: atanh: 137441755136.000000 ulp error at -0x1.0000000000000p-39 (0xbd80000000000000): *-0x1.0000000002000p-39 vs. -0x1.0000000155555p-15
ERROR: atanh: 536870976.000000 ulp error at -0x1.0000000000000p-39 (0xbd80000000000000): *-0x1.0000000002000p-39 vs. -0x1.0000000000015p-23
ERROR: atanh: 2097152.000000 ulp error at -0x1.0000000000000p-39 (0xbd80000000000000): *-0x1.0000000002000p-39 vs. -0x1.0000000000000p-31
ERROR: atanh: 8192.000000 ulp error at -0x1.0000000000000p-39 (0xbd80000000000000): *-0x1.0000000002000p-39 vs. -0x1.0000000000000p-39
ERROR: atanh: 32.000000 ulp error at -0x1.0000000000000p-39 (0xbd80000000000000): *-0x1.0000000002000p-39 vs. -0x1.0000000000000p-47
ERROR: atanh: 6.000000 ulp error at -0x1.a900000000000p-35 (0xbdca900000000000): *-0x1.a900000058322p-35 vs. -0x1.a900000000000p-51
How to understand the output:
Error ULP difference, input value printed as cl_double (input value printed as cl_ulong), reference value (cpu), output value (gpu)
Link to source code:
https://github.com/KhronosGroup/OpenCL-CTS/blob/main/test_conformance/math_brute_force/unary_double.cpp#L349
battlegoat
GrzegorzW
Hi
For settings "/Qlong-double /Qpc80 /fp:strict"  the same
VarshaS_Intel
We are investigating your issue at our end.
Thanks & Regards,
Varsha
VarshaS_Intel
As per the confirmation from you through email, we are closing this thread.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Varsha
