This morning I got an automatic update to Xcode 9.0 and the Intel C++ compiler no longer works with the option -std=c++11. For the simple routine
#include<stdlib.h>
#include<iostream>
#include<map>
int main(int argc,char **argv)
double x[10], y[10];
x[0] = 1.0;
x[1] = 0.0;
x[2] = 2.0;
x[3] = -7.0;
x[4] = 8.0;
x[5] = 100.0;
x[6] = -17.0;
x[7] = -15.0;
x[8] = 5.0;
x[9] = 1.0;
for (int i = 0; i < 10; ++i)
y = x;
std::map<double,double> M;
if (M.find(x) == M.end())
M[x] = y;
else
std::cerr << "Duplicate x found\n";
std::map<double,double>::iterator q;
for (q = M.begin(); q != M.end(); ++q)
std::cout << "q->first = " << q->first << ", q->second = " << q->second << "\n";
The compile line "icpc -c -std=c++11 Map.cc" yields the long error message
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/__tuple(406): error: template instantiation resulted in unexpected function type of "auto (std::__1::__tuple_types<const double &>, std::__1::__tuple_types<const double &>)->std::__1::__all<(bool)true>" (the meaning of a name may have changed since the template declaration -- the type of the template is "auto (std::__1::__tuple_types<_LArgs...>,
std::__1::__tuple_types<_RArgs...>)->std::__1::__all<(std::__1::enable_if<_Trait<_LArgs, _RArgs>::value, bool>::type{true})...>")
using __constructible = decltype(__do_test<is_constructible>(_ToArgs{}, _FromArgs{}));
detected during:
instantiation of "std::__1::__tuple_sfinae_base::__do_test" based on template arguments <std::__1::is_constructible, const double &, const double &> at line 406
instantiation of type "std::__1::__tuple_sfinae_base::__constructible<std::__1::__tuple_types<const double &>, std::__1::__tuple_types<const double &>>" at line 440
instantiation of class "std::__1::__tuple_constructible<_Tp, _Up, true, true> [with _Tp=std::__1::tuple<const double &>, _Up=std::__1::__tuple_types<const double &>]" at line 513 of "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple"
instantiation of "bool std::__1::tuple<_Tp...>::_CheckArgsConstructor<true, _Dummy>::__enable_explicit<_Args...>() [with _Tp=<const double &>, _Dummy=void, _Args=<const double &>]" at line 1104 of "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple"
instantiation of "std::__1::tuple<_Tp &&...> std::__1::forward_as_tuple(_Tp &&...) [with _Tp=<const double &>]" at line 1368 of "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/map"
instantiation of "std::__1::map<_Key, _Tp, _Compare, _Allocator>::mapped_type &std::__1::map<_Key, _Tp, _Compare, _Allocator>::operator[](const std::__1::map<_Key, _Tp, _Compare, _Allocator>::key_type &) [with _Key=double, _Tp=double, _Compare=std::__1::less<double>, _Allocator=std::__1::allocator<std::__1::pair<const double, double>>]" at line 28 of "Map.cc"
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/__tuple(437): error: not a class or struct name
: public __tuple_sfinae_base::__constructible<
detected during:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(513): error: class "std::__1::__tuple_constructible<std::__1::tuple<const double &>, std::__1::__tuple_types<const double &>, true, true>" has no member "value"
>::value &&
detected during:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/__tuple(408): error: template instantiation resulted in unexpected function type of "auto (std::__1::__tuple_types<const double &>, std::__1::__tuple_types<const double &>)->std::__1::__all<(bool)true>" (the meaning of a name may have changed since the template declaration -- the type of the template is "auto (std::__1::__tuple_types<_LArgs...>,
using __convertible = decltype(__do_test<is_convertible>(_FromArgs{}, _ToArgs{}));
detected during:
instantiation of "std::__1::__tuple_sfinae_base::__do_test" based on template arguments <std::__1::is_convertible, const double &, const double &> at line 408
instantiation of type "std::__1::__tuple_sfinae_base::__convertible<std::__1::__tuple_types<const double &>, std::__1::__tuple_types<const double &>>" at line 425
instantiation of class "std::__1::__tuple_convertible<_Tp, _Up, true, true> [with _Tp=std::__1::tuple<const double &>, _Up=std::__1::__tuple_types<const double &>]" at line 520 of "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple"
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/__tuple(422): error: not a class or struct name
: public __tuple_sfinae_base::__convertible<
detected during:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(520): error: class "std::__1::__tuple_convertible<std::__1::tuple<const double &>, std::__1::__tuple_types<const double &>, true, true>" has no member "value"
>::value &&
detected during:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(538): error: class "std::__1::__tuple_convertible<std::__1::tuple<const double &>, std::__1::__tuple_types<const double &>, true, true>" has no member "value"
>::value &&
detected during:
instantiation of "bool std::__1::tuple<_Tp...>::_CheckArgsConstructor<true, _Dummy>::__enable_implicit<_Args...>() [with _Tp=<const double &>, _Dummy=void, _Args=<const double &>]" at line 1104
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(1104): error: no instance of constructor "std::__1::tuple<_Tp...>::tuple [with _Tp=<const double &>]" matches the argument list
argument types are: (const double)
return tuple<_Tp&&...>(_VSTD::forward<_Tp>(__t)...);
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(869): note: this candidate was rejected because mismatch in count of arguments
tuple(allocator_arg_t, const _Alloc& __a, _Tuple&& __t)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(855): note: this candidate was rejected because mismatch in count of arguments
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(842): note: this candidate was rejected because at least one template argument could not be deduced
tuple(_Tuple&& __t) _NOEXCEPT_((is_nothrow_constructible<base, _Tuple>::value))
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(827): note: this candidate was rejected because at least one template argument could not be deduced
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(808): note: this candidate was rejected because mismatch in count of arguments
tuple(allocator_arg_t, const _Alloc& __a, _Up&&... __u)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(788): note: this candidate was rejected because mismatch in count of arguments
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(761): note: this candidate was rejected because at least one template argument could not be deduced
tuple(_Up&&... __u)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(728): note: this candidate was rejected because at least one template argument could not be deduced
tuple(_Up&&... __u)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(702): note: this candidate was rejected because mismatch in count of arguments
tuple(allocator_arg_t, const _Alloc& __a, const _Tp& ... __t)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(682): note: this candidate was rejected because mismatch in count of arguments
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(664): note: this candidate was rejected because at least one template argument could not be deduced
explicit tuple(const _Tp& ... __t) _NOEXCEPT_((__all<is_nothrow_copy_constructible<_Tp>::value...>::value))
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(646): note: this candidate was rejected because at least one template argument could not be deduced
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(630): note: this candidate was rejected because mismatch in count of arguments
tuple(_AllocArgT, _Alloc const& __a)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(621): note: this candidate was rejected because arguments do not match
tuple(tuple&&) = default;
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(620): note: this candidate was rejected because arguments do not match
tuple(tuple const&) = default;
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include/c++/v1/tuple(617): note: this candidate was rejected because mismatch in count of arguments
_LIBCPP_CONSTEXPR tuple()
detected during:
compilation aborted for Map.cc (code 2)
Leaving out the -std=c++11 option makes this test compilable and runable. This same problem occurred for the Intel 17 version.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
The XCode 9 is released after our 18.0 release, it is not officially supported yet. This issue is known and we're working on the fix. Please try the future 18.0 update.
thanks,
Jennifer
Do we know when the update would be available ?
Mathieu
this issue has been fixed in the 18.0 update 1.
thanks,
Jennifer
This still seems broken when trying to use Xcode 9.2 with Intel Composer 2018.1.031
