I've run into a code generation issue when using the Intel compiler and filed an issue with Intel Premier on 8/25, which was escalated to engineering shortly thereafter. Unfortunately it's been stuck ever since, and there was no response to some follow-up questions.
The issue title is: "Extremely poor vectorized code generation by Intel C++ compiler (AVX512)" (ID 6000162527)
It would be great if somebody could look into this.
Hi Wenzel,
I have not received any update from the Engineering team . I will let you know as soon as i have an update. I also have raised the priority of this issue.
Varsha
