Intel® C++ Compiler
7782 Discussions
IntelC++ failed to compile thread_local extern std::stringstream::str(std::string) correctly
Liu__Bensong
I got a `segmentation fault` after compiling code below with icpc. However, clang++ and g++ compile it correctly.
// bug.cc
#include <sstream>
#include <string>
thread_local extern std::stringstream foo;
int main() {
    foo.str(std::string());
    return 0;
// lib.cc
#include <sstream>
thread_local std::stringstream foo;
Here's a screenshot while I'm reproducing the problem.
screenshot on error
Source files and the log is attached. My OS is latest ArchLinux, and other OS information is shown on the screenshot.
Viet_H_Intel
Intel compiler version 18.0 doesn't support GCC 8.1. If you compile the test program on the system which had GCC 4.3 to 6.3 installed, then it should work.
Viet
