Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Internal Error
The intel compiler generates this:
../simd/avx.hpp(50): internal error: assertion failed at: "shared/cfe/edgcpfe/decls.c", line 9448
      static constexpr unary_value initialize = _mm256_set1_pd;
Here's how I generated the attached preprocessed file:
/compilers/intel/composer_xe_2019.3.199/compilers_and_libraries/linux/bin/intel64/icpc  -std=c++14 -mavx2  -o junk.pp -c junk.cpp -E
Can someone try to reproduce this on Linux?
Highlighted
The error is reproducible on Linux. Apparently, from the error log, line number 3 of junk.cpp is triggering the error.
Do you mind sharing the minimal reproducible source code, so as to try and understand the root cause of the error?
--Rahul
Highlighted
Please see the attached files, you should be able to reproduce the problem with:
 icpc -std=c++17 -mavx2  -c junk.cpp -I.
Highlighted
Ignore previous attachment, those are the wrong files,
Highlighted
Note that I get the same error on the Mac with intel 19.
avx.hpp(69): internal error: assertion failed at: "shared/cfe/edgcpfe/decls.c", line 9486
Highlighted
Hi Noel,
Looks like a bug to me. Thanks for reporting this and providing sample codes, preprocessed files.
I will escalate this issue to the concerned team.
Rahul
Highlighted
Thanks for the bug report. You can work around this compiler bug by providing a wrapper function around the intrinsic function. For example, add this function
#include <immintrin.h>
__m256d wrap_mm256_set1_pd (double d) {
  return _mm256_set1_pd(d);
And instead of referring to the intrinsic within the template, use the wrapper function's name,
static constexpr unary_value initialize = wrap_mm256_set1_pd;
Hope this helps. --Melanie
Highlighted
Here is another workaround that doesn't require you to modify your source code, you can #define this symbol or put it into the compiler flags
icpc -c -D__INTEL_COMPILER_USE_INTRINSIC_PROTOTYPES=1 test.cpp
