Intel® C++ Compiler
Internal access violation in compiler
Manuel_P_
Try this: struct X { int i; X(int i) : i(i) {} ~X() {} // This destructor causes access violation in Intel compiler while compiling. }; vector f() { // Causes access violation in Intel compiler, if // - X has a destructor, and // - explicit cast int to X is called. With implicit cast it works. // return { 1, 2 }; // Ok. return { X(1), X(2) }; // Access violation. } It will result in a compiler error saying "error : access violation". I use this version: Intel(R) C++ Intel(R) 64 Compiler XE for Intel(R) 64, version 14.0.3 Package ID: w_ccompxe_2013_sp1.3.202, the previous version had the same issue. Cheers, Martin
Manuel_P_
Here is a better formatted version: [cpp] struct X { int i; X(int i) : i(i) {} ~X() {} // This destructor causes access violation in Intel compiler while compiling. }; vector<X> f() { // Causes access violation in Intel compiler, if // - X has a destructor, and // - explicit cast int to X is called. With implicit cast it works. // return { 1, 2 }; // Ok. return { X(1), X(2) }; // Access violation. } [/cpp]
Bernard
Valued Contributor I
Looks like internal compiler error.
Bernard
@martin
Do you have Windows or Linux?
Manuel_P_
Yes, this is the output:
1>------ Build started: Project: ng-gtest, Configuration: Release x64 ------
1>  InitializerListTest.cpp
1>General\InitializerListTest.cpp(57): error : access violation
1>    	return { X{1}, X{2} }; // Access violation.
1>    	       ^
1>
1>  compilation aborted for General\InitializerListTest.cpp (code 4)
========== Build: 0 succeeded, 1 failed, 3 up-to-date, 0 skipped ==========
Manuel_P_
Windows 7, x64.
Bernard
Compiled and ran your test-case and got access violation.
Here is the output:
1>  stdafx.cpp
1>  IDZ_test111.cpp
1>IDZ_test111.cpp(16): error : access violation
1>        return{ X(1), X(2) };
1>        ^
1>
1>  compilation aborted for IDZ_test1.cpp (code 4)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Bernard
Tried to run Visual Studio under windbg , but unfortunately cannot break on access violation exception.
Bernard
Any response from Intel engineers?
QIAOMIN_Q_
Hello Martin,
>icl /Qstd=c++0x /c /Od 515182u.cpp
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Ve
rsion 14.0.3.202 Build 20140422
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
515182u.cpp
515182u.cpp(12): error: vector is not a template
  vector<X> f()
515182u.cpp(24): error: too many initializer values
compilation aborted for 515182u.cpp (code 2)
What's your visual studio's version? vs2012? and what's your compilation switches? Maybe vs2013 is the minimum VS version which fully support the C++11 initializer ,I will let you know after I upgraded to it.
Thank you.
QIAOMIN.Q
Intel Developer Support
Please participate in our redesigned community support web site:
User forums:                   http://software.intel.com/en-us/forums/
Manuel_P_
Hi Qiaomin,
I use Visual Studio Premium 2013.
This is the output:
1>  icl /Qvc12 "/Qlocation,link,D:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64" /Zi /W3 /MP /O3 /Oi /Qip /Qftz -D __INTEL_COMPILER=1400 -D WIN32 -D NDEBUG -D _CONSOLE -D NG_EXPORTS -D NG_DLL_ID=1 -D USE_TBB_PARALLEL -D USE_TBB_RWLOCK -D NOMINMAX -D BOOST_FILESYSTEM_NO_DEPRECATED -D _WINDLL -D _SCL_SECURE_NO_WARNINGS -D BOOST_MULTI_INDEX_DISABLE_SERIALIZATION -D NOMINMAX -D _WINDLL -D _VARIADIC_MAX=10 -D _UNICODE -D UNICODE /EHsc /MD /GS /fp:precise /QxSSE3 /Zc:wchar_t /Zc:forScope /Qstd=c++11 /Qrestrict /Fo.\tmp\msvc_x64_ur\ /Fd.\tmp\msvc_x64_ur\vc120.pdb /TP General\InitializerListTest.cpp
1>
1>  Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.3.202 Build 20140422
1>  Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
1>
1>               ^
1>
Bernard
@Qiaomin
I have VS 2013 and the same error description.
QIAOMIN_Q_
This has been reproduced and the bug smells like a front-end compatability problem since /Od also caused failure and /E fine,I will reported to some developers to see any workaround for you and will get you posted whenever I got some updates.
Thank you.
QIAOMIN.Q
