The following c code compiles with gcc, but fails to compile with icc: file ier.c:
[bash]typedef struct ar_u { short raw; } ar_t;
typedef union format_u { struct { ar_t ar; unsigned limit; }; } format_t; int main () { format_t data = { .limit = 0x31 }; return 0; } [/bash]
Error message:
ier.c(8): internal error: assertion failed at: "shared/edgcpfe/decl_inits.c", line 1964
compilation aborted for ier.c (code 4)
Thanks for reporting the issue and with a testcase.
I can duplicate it with our latest 11.1 for Linux. But the 12.0 works fine.
The 12.0 version will be coming out shortly. so please wait.
Thanks again,
Jennifer
$ icc -c er.c
er.c(7): internal error: assertion failed at: "shared/edgcpfe/decl_inits.c", line 1975format_t data = { .limit = 0x31 };
^compilation aborted for er.c (code 4)
Thanks again,
Jennifer
