Intel® C++ Compiler
Internal error: 0_1428
mrgronk
Hi all,
I've come across a problem in the Intel C/C++ compiler for Mac OS X, and would like any advice on fixes, or alert the code maintainers to it.
The situation is this: I compile the attached file, and get the following result:
[user@computer dir]$ icc -c -o 091006_amber.o 091006_amber.c
091006_amber.c(26) (col. 1): internal error: 0_1428
compilation aborted for 091006_amber.c (code 4)
This error can be avoided by doing any of the following:
- Reducing the optimisation level from the default (i.e., -O2) to -O1
- Removing from among the list of included headers
- Removing the memset line from childsub()
- Removing the whole while() loop inside childsub() (however, removing all contents of the while loop and leaving the while(1){ } causes an abort)
- Removing parentsub(), even though all it does is call childsub()
There may be other workarounds that I have not yet discovered. Nevertheless, these all seem to be workarounds rather than fixes. It's also true that this file is very much a stub, and is the smallest possible file I could make that reproduces the error, so many of the workarounds I offered won't work in the general case. For the time being, I'm reducing the optimisation level when building the affected file in my program.
System information:
- Mac OS X 10.6, Snow Leopard (10.6.1), running either the "32-bit" or the "64-bit" kernel (I have forced boot into the full 64-bit kernel, and the same problem crops up under either kernel)
- Intel C/C++ compiler 11.1.067 (build date 2009-08-27), according to icc --version
I have attached the code that causes the problem. Any insight would be much appreciated. Code:
[cpp]#include
#include
typedef char    SHORTt[10];
typedef struct  {
        char            sName[10];
        int             iEquivs;
        SHORTt          saEquivs[20];
} EQUIVt;
static void
childsub( FILE *fIn )
EQUIVt          eEquiv;
int             i;
    memset(&eEquiv, 0, sizeof(eEquiv));
    while (1) {
        eEquiv.iEquivs = i;
void
parentsub( FILE *fIn )
    childsub( fIn );
}[/cpp]
Thanks in advance.
TimP
Intel C++ Compiler Professional for applications running on IA-32, Version 1
.1 Build 20090903 Package ID: w_cproc_p_11.1.046
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
mrg.c
mrg.c(19): error #12082: infinite loop
mrg.c(20): error #12143: "i" is uninitialized
Don't know why the Mac compiler should be any different.
mrgronk
Quoting - tim18
Neither do I, but it is. It doesn't complain about infinite loops. In the original file, this code was looping over entries in a file, I think, or some other data structure where the structure itself contained the termination. I didn't really want to include all that stuff.
Quoc-An_L_Intel
With the given code sample, I can't reproduce the internal error. See below.
This is on a system with OSX 10.6.1, Xcode 3.2, ICC 11.1.067. This is a Mac Pro with Quad core
spd48:ale super$ cat u68863.cpp
#include
#include
typedef struct {
char sName[10];
int iEquivs;
} EQUIVt;
static void
EQUIVt eEquiv;
int i;
while (1) {
eEquiv.iEquivs = i;
void
childsub( fIn );
spd48:ale super$
spd48:ale super$ sw_vers
ProductName: Mac OS X
ProductVersion: 10.6
BuildVersion: 10A432
spd48:ale super$ icc -V -c -o u68863.o u68863.cpp
Intel C Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20090827 Package ID: m_cproc_p_11.1.067
Edison Design Group C/C++ Front End, version 3.10.1 (Aug 27 2009 20:13:12)
Copyright 1988-2007 Edison Design Group, Inc.
spd48:ale super$
mrgronk
Quoting - Qale (Intel)
spd48:ale super$
OK, but isn't that trying to interpret it as a C++ file? It should be plain C.
Quoc-An_L_Intel
Quoting - mrgronk
OK I see the internal error now. But it looks like a problem only on Snow Leopard Mac OS X 10.6.1. I don't see it on 10.5.
spd44:ale super$ sw_vers
ProductVersion: 10.5.6
BuildVersion: 9G55
spd44:ale super$ icc -c -V -o u68863.o u68863.c
spd44:ale super$
Quoc-An_L_Intel
A defect was file against this problem. Thesupport issue is #565937.
mrgronk
Thanks Qale. Is there anything more I need to do at this time?
Quoc-An_L_Intel
I'll post an update here when a fix is available.
Quoc-An_L_Intel
This problem isresolved in the latest update version 11.1 update 3.
