Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7725 Discussions
Internal error: assertion failed at: "shared/cfe/edgcpfe/decl_inits.c", line 588
Luke_D_
I am running into the following ICE with the following relatively minimalized test case.
template <char>
struct Index {
  constexpr Index() : value_(0) {
 private:
  int value_;
template <int>
int foo() {
  static constexpr Index<'i'> i;
  return 0;
int bar() {
  return foo<3>();
See versions below
[...]:~/test> gcc --version
gcc (GCC) 6.3.0 20161221 (Cray Inc.)
Copyright (C) 2016 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
[...]:~/test> icpc --version
icpc (ICC) 17.0.2 20170213
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
[...]:~/test> gcc -std=c++14 -c -o test.o test.cpp
[...]:~/test> icpc -std=c++14 -c -o test.o test.cpp
compilation aborted for test.cpp (code 4)
This can be reproduced across lots of platforms and compiler versions, though this particular instance is in the Cray Linux Environment with PrgEnv-intel/6.0.3 and gcc/6.3.0
TimP
Black Belt
This seems reproducible with various icpc versions including 18.0.0.061, regardless of whether the g++ on PATH is recent enough to accept the code.
Judith_W_Intel
Thank you for reporting this. I was able to reproduce it in our 18.0 and 17.0 compilers and have entered a bug report in our internal bugs database with number cmplrs-43144. We hope to have a fix soon.
Judy
Tolmie__Shane
Just ran into the exact same problem again with Intel Compiler v19.0:
Internal error: assertion failed at: "shared/cfe/edgcpfe/exprutil.c", line 6647
The error appears to be random. The exact same code works perfectly fine if copied and pasted into another project.
SUKLA
Viet_H_Intel
I tried the code but didn't see the error with version 19.1.3.
$ icpc -std=c++14 t2.cpp -c -V
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.3.304 Build 20200925_000000
Copyright (C) 1985-2020 Intel Corporation.  All rights reserved.
Edison Design Group C/C++ Front End, version 5.0 (Sep 25 2020 02:11:08)
Copyright 1988-2018 Edison Design Group, Inc.
$ cat t2.cpp
template <char>
struct Index {
 private:
  int value_;
template <int>
int foo() {
  return 0;
int bar() {
  return foo<3>();
