I'm running into a pesky internal compiler error with the attached preprocessed file. It would be great if this could be fixed.
$ icpc test.ii -std=c++14 -xMIC-AVX512 Internal error loop: assertion failed: find_seq_in_lookup_table: seq_number not found (shared/cfe/edgcpfe/il.c, line 4039)
Wenzel
This is the compiler version:
icpc version 16.0.3 (gcc version 4.9.3 compatibility)
ld /usr/lib/../lib64/crt1.o /usr/lib/../lib64/crti.o /ssoft/spack/lafnetscha/opt/spack/x86_E5v1_IntelIB/gcc-4.4.7/gcc-4.9.3-2gys3tu6lq35ge6woeixfo4tfz5nnvzn/lib64/gcc/x86_64-unknown-linux-gnu/4.9.3/crtbegin.o --eh-frame-hdr --build-id -dynamic-linker /lib64/ld-linux-x86-64.so.2 -m elf_x86_64 -o a.out -L/ssoft/spack/external/intel/2016/compilers_and_libraries_2016.3.210/linux/bin/lib_lin -L/ssoft/spack/lafnetscha/opt/spack/x86_E5v1_IntelIB/gcc-4.4.7/gcc-4.9.3-2gys3tu6lq35ge6woeixfo4tfz5nnvzn/lib64/gcc/x86_64-unknown-linux-gnu/4.9.3/ -L/ssoft/spack/lafnetscha/opt/spack/x86_E5v1_IntelIB/gcc-4.4.7/gcc-4.9.3-2gys3tu6lq35ge6woeixfo4tfz5nnvzn/lib64/gcc/x86_64-unknown-linux-gnu/4.9.3/../../../../lib64 -L/ssoft/spack/lafnetscha/opt/spack/x86_E5v1_IntelIB/gcc-4.4.7/gcc-4.9.3-2gys3tu6lq35ge6woeixfo4tfz5nnvzn/lib64/gcc/x86_64-unknown-linux-gnu/4.9.3/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/ssoft/spack/lafnetscha/opt/spack/x86_E5v1_IntelIB/gcc-4.4.7/gcc-4.9.3-2gys3tu6lq35ge6woeixfo4tfz5nnvzn/lib64/gcc/x86_64-unknown-linux-gnu/4.9.3/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -L/ssoft/spack/external/intel/2016/compilers_and_libraries_2016.3.210/linux/ipp/lib/intel64 -rpath=/ssoft/spack/external/intel/2016/compilers_and_libraries_2016.3.210/linux/ipp/lib/intel64 -L/ssoft/spack/external/intel/2016/compilers_and_libraries_2016.3.210/linux/tbb/lib/intel64/gcc4.4 -rpath=/ssoft/spack/external/intel/2016/compilers_and_libraries_2016.3.210/linux/tbb/lib/intel64/gcc4.4 -L/ssoft/spack/external/intel/2016/compilers_and_libraries_2016.3.210/linux/mkl/lib/intel64 -rpath=/ssoft/spack/external/intel/2016/compilers_and_libraries_2016.3.210/linux/mkl/lib/intel64 -L/ssoft/spack/external/intel/2016/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64 -rpath=/ssoft/spack/external/intel/2016/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64 -rpath=/ssoft/spack/lafnetscha/opt/spack/x86_E5v1_IntelIB/gcc-4.4.7/gcc-4.9.3-2gys3tu6lq35ge6woeixfo4tfz5nnvzn/lib64 -Bdynamic -Bstatic -limf -lsvml -lirng -Bdynamic -lstdc++ -lm -Bstatic -lipgo -ldecimal --as-needed -Bdynamic -lcilkrts --no-as-needed -lstdc++ -lgcc -lgcc_s -Bstatic -lirc -lsvml -Bdynamic -lc -lgcc -lgcc_s -Bstatic -lirc_s -Bdynamic -ldl -lc /ssoft/spack/lafnetscha/opt/spack/x86_E5v1_IntelIB/gcc-4.4.7/gcc-4.9.3-2gys3tu6lq35ge6woeixfo4tfz5nnvzn/lib64/gcc/x86_64-unknown-linux-gnu/4.9.3/crtend.o /usr/lib/../lib64/crtn.o
Thanks for reporting this. I have reduced it to this small example below which gives the assertion even in our development compiler.
I have entered DPD200413420 in our internal tracking bugs database to fix this bug. thanks for reporting it.
As you can see it looks to be a problem that is triggered by inheriting constructors.
template <typename Type>
void foo2(Type x) {
Type(double(1));
struct B2
B2(double);
struct B : public B2 {
using B2::B2;
B();
struct A : public B
using B::B;
void foo() {
A a;
foo2(a);
This was fixed in 17.0 on 09/26 so yes it should be fixed in 17.0 update 1 which should be available very soon.
Sorry but I can't think of a simple workaround
Judy
Hi Lukas,
We've released 17.0 Update 1 which has this problem fixed.
$ icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
Viet
Is this issue also resolved in icc16, if yes which version?
We don't have any more update for icc16.
