Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
7677 Discussions
Internal error with Intel xiar 2016 on linux 64-bit
Adrien_L_
Hi everyone,
We are currently using Intel Parallel Studio XE v2016.1.056 which embeds "Compilers and libraries" v2016.1.150 on CentOS 64-bit and we encountered a problem with the xiar tool.
The issue should be reproductible by calling:
$> xiar rb object1.o lib.a object2.o
That prompts "xiar: internal error: Assertion failed (shared/driver/linker.c, line 6832)" whether or not the ".o" and ".a" files exist or not.
But, if you run:
$> xiar r lib.a object.o
It will have the expected behaviour (checking files, and adding "object.o" to "lib.a").
Therefore, the issue seems to come from the "b" option which would normally add "object2.o" before "object1.o" in "lib.a". We never encountered this issue with the version 2013.5.192 of Composer XE and GNU ar v2.20 (which is used by xiar) supports the "b" option. The obvious way to circumvent this problem for us was to stop using the "b" option (or to call GNU ar instead of xiar) but it may not be a valid solution for everyone...
Adrien L.
Software Developer at OPAL-RT Technologies
MalReddy_Y_Intel
Thanks for reporting this issue. We have escalated this issue to engineering team and keep inform you with updates.
Reddy
