Intel® C++ Compiler
7838 Discussions
Invalid handling of newlines in raw string literals
Gerd_K_
Given the following test code compiled with Intel C++ Compiler XE 14.0
#include "stdafx.h"
#include <iostream>
using namespace std;
int _tmain(int argc, _TCHAR* argv[])
    auto raw = LR"(1
2)";
    std::wcout << raw << endl;
    return 0;
the actual output on the console is
1\n2
expected output
1
2
Is this a bug in the compiler?
Shenghong_G_Intel
Hi Gerd,
It works for me with 15.0 compiler, did you try that?
Intel(R) C++ Compiler XE for applications running on IA-32, Version 15.0.1.148 B
uild 20141023
# type test.cpp
#include <iostream>
int main()
    auto raw = LR"(1
2)";
    return 0;
# icl test.cpp /nologo
test.cpp
# test.exe
1
2
Shenghong
Gerd_K_
I can confirm, it is working in 15.0. But because of other problems with 15.0 it's currently not possible for us to upgrade.
I wonder how such a basic usecase for raw string literals hasn't been fixed in any update.
Kittur_G_Intel
Hi Shenghong,  I presume you filed an issue with the developers just in case they would like to backport the fix to earlier versions?
Shenghong_G_Intel
Hi Gerd/Ganesh,
Yes, I'll check with developer whether we can backport the fix to earlier versions. I did not tested v14.0 yesterday (I'll verify it soon). I agree such basic stuff should be fixed in old versions and I assume it is not technically difficult to fix.
I'll keep you updated.
Shenghong
Shenghong_G_Intel
Hi Gerd,
I've got updates from developer, there are no new update for v14.0, it cannot be back-port to v14.0 compiler. You have to upgrade to v15.0, what are the other problems you are facing with v15.0? You may push those issues to be fixed and have a upgrade.
Shenghong
Gerd_K_
The other issues we had seem to be not caused by the compiler upgrade. It seems to be caused by a bug in an external component that unfortunateley showed up when we tried the upgrade to v 15.
So we will upgrade to v15 in near future.
Kittur_G_Intel
Thanks Shenghong for checking with the developer. Upgrading to 15.0 (especially considering there are new features/bug fixes) is a good idea Gerd.
_KIttur
