Intel® C++ Compiler
7956 Discussions
Is It possible to use Intel C++ compliler for windows Application project (i.e. GUI Application, consisting Parallellizing concepts)
rrr1989
I have tried Parallel studio by working under a project of type win32 Console Application... (dot net 2008, Visual c++)
So Is it possible to create and compile successfully a project of type Windows Application(which can include parallelizing concept)..?
so that i can create GUI form (not win32 console application).. which can execute some code parallely???
(I am asking this question Because i tried it but i got some errors while compiling so only i am not sure whether it works for GUI or not)
Thanks in advance..
With regards,
~ RRR
JenniferJ
No, you can not use Intel C++ with a CLR project.
You can create the GUI project with CLR, but create a DLL project in C++ (no attributes) to use Intel C++.
Jennifer
Om_S_Intel
You should be able to compile application that use MFC. Intel C++ compileris strivingto compile application that you can compiler with Microsoft compiler.
It would help if you can share a test case.
rrr1989
Is it possible to use Intel C++ Compiler for Windows Application (i.e. tat use CLR)... ???
JenniferJ
Jennifer
rrr1989
Can you explain me in few steps (atleast an overview) as to how to do as you said above... Because i am a newbie...
Om_S_Intel
CLR is not supported by Intel C++ compiler.
TimP
Microsoft provides documentation on how to run C++ unmanaged code (such as ICL generates) from a CLR application. ICL documentation tells you how to make a .dll for such purposes.
