I have icl v.11 for win32 on 30-day evaluation - It does not appear to have any support for 64-bit architecture. Is a windows 64-bit equivalent available on the same basis ? If so where do I download it, and can I use the 2 compilers in parallel on different machines (contractually, I mean - not technically!)
Your eval license allowsall the compilers to be used for 30 days.
it seems you only download/installed the ia32 package. You should be able to download the other packages or download the full package at https://registrationcenter.intel.com/RegCenter/Register.aspx
And yes, you can install the compilers to different machines for your use only.
Jennifer
Jennifer
Jennifer
Jennifer
Topic Options
