If I use -opt-reportx where x is one of 0,1,2 or 3 compilation is suppressed but no report output. This is with O1 and O2 optimisation.
If I use -opt-report-phase=all or -opt-report-phase=hlo I get reporting on optimisation and object files generated.
If I try -opt-report-phase=hlo with -opt-reportx I get the same reporting on optimisation but no object file generated
regards
David
regards
David
I wonder if you're running into the situation where the compiler doesn't recognize your -opt-report because of a minor spelling mismatch, and so creates an output file named something like pt-reportx.
Yes. In the latest compiler you need to enable vector diagnostic using -diag-enable:vec. By default this is off.
Thanks for the reply, Om. But I don't think that deals with the situation I'm seeing.
opt-report is not generating any optimisation reporting on Linux with ICC 12.0. It is doing something as object files are not being generated when the opt-report switch is used.
I can generate optimisation output with opt-report-phase. I can generate for various phases such as hlo, hpo. But I can't control how much output I get for each phase.
I can also use the vec-reportx switch to generate vectorisation specific reporting. The level of vectorisation output is controllable by varying x.
I have an anomalous situation where optimisation switches that generated much faster code on MS7 with ICC11.x are not having a positive impact on Linux with ICC12.0. I was hoping to use the opt-report switch to identify what is or isn't happening. Wading through the output from opt-report-phase is a lengthy process.
I need to make recommendations to management on the production build environment. All I can say at the moment is that ICCO2 works better than the version of gcc currently being used in production. Be nice to have some other ICC switches providing a benefit
David
David
Thanks, Tim. The compiler manual says that you need to have a space between the -opt-report and the n on Linux. Don't need the space on Windows. So as you correctly inferred it was generating obj files called pt-reportx ie reading it as -o etc
My bad.
A bit of less than super computing on my part
David
My bad.
David
