I have been porting a working project from VC++ to ICC. While compilation it game me an error
error: invalid redeclaration of type name "size_t"
typedef ADDRESS size_t
I dont see any problem with this typedef. Only thing which comes to my mind is usage of keyword size_t. If ICC alreday has this keyword then it may not allow me to redifne me.
Can any one tell me if there is any other reason for the error.
Abhi
Abhi
Abhi, size_t is used inside the "std" namespace. For instance, asking a std::vector for its size is of type std::size_t.
I would restrain from using size_t in c++ code.
Christian
Perhaps this should be rephrased along the lines of "refrain from re-defining size_t in C or C++." I would not like to express approval of the school of thought which says compilers where int and size_t aren't interchangeable are broken. I've wasted months of work myself trying to work with those who hold such opinions.
In the past, some Microsoft C++ programmers disdained the use of size_t in C and C++ standards, and ICL also avoided its use, preferring to introduce portability problems between ia32 and X64. I notice that my current ICL installation has introduced size_t in the definition of local variations on malloc() and mmap() so as to fix such problems.
Correctness could easily depend on not defeating the use of size_t in C and C++ standard function prototypes by attempting to redefine it. If you have a data type of your own which you want to typedef to whatever you choose, you shouldn't be using a name for it which is reserved by the standards.
size_t is used in C++ (stddef.h, stdlib.h) and operator sizeof() evaluates to size_t. It is a reserved word which should not be redefined. Same goes for ptrdiff_t.
What today's schools do not teach developers is that size_t is used to overcome portability problems.
In general, if sizeof(int) != sizeof(ptr) on a particular architecture, you have to use size_t instead of int or you will have to write two versions of each function which has int as a parameter.
There is a very good explanation here:
http://www.viva64.com/en/a/0050/
I suggest that those developers who are engineering and writing IPP library API at Intel read it as well. It can save them a lot of effort in the future now that people are asking for 64-bit support in IPP functions.
