Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7767 Discussions
Is the /FR option --> icl: warning #10210 -->BSCMAKE: error BK1506 already solved?
_heinz
Hallo,
I run "Intel Parallel Studio" update 4 and get the icl: warning #10210 and BSCMAKE: error BK1506 when /FR is set in Enable Browse Information
If I switch offthe/FR option then the project compiles successful.
Question:
Is this problem with the /FR option already solved now?
thanks
heinz
Om_S_Intel
Could you please post your sample code to makereview easy ?
