Intel® C++ Compiler
7956 Discussions
Is the Intel C++ Compiler (19.0) now only using the Clang front-end (i.e. already abandoned EDG)?
Ng__Zeson
In 16.0, the Intel C++ Compiler provided two compilers (one based on EDG, another based on Clang).
From the 16.0 documentation:
Using the Command Line
To invoke the compiler from the command line, use a command similar to the following:
For C source files: icc my_source_file.c or icl my_source_file.c
For C++ source files: icpc my_source_file.cpp or icl++ my_source_file.cpp
Following successful compilation, the compiler creates an executable file in the current directory.
icl/icl++ is a Clang-based front-end. You can use Clang options with this compiler. icc/icpcis an EDG-based front-end. You cannot use Clang options with icc/icpc.
But I'm not seeing a similar description now in 19.0 document.
Hsbsh
So, this says at least for MacOS icl++ (which does not exist on windows, BTW, or Linux) uses clang while Edison design g. is for icc. https://web.archive.org/web/20150905074805/https://software.intel.com/en-us/get-started-with-cpp-compiler-for-osx-parallel-studio-xe
But then again, MacOS uses clang. Windiwd icl is different, while on linux icl is called icc.
