Intel® C++ Compiler
7833 Discussions
Is there a performance difference between these two loops?
HD86
The following two code samples do the same thing, but is one of them more efficient than the other?
void foo(char *p)
	while (*p != 0)
		*p = 0;
		++p;
void foo(char *p)
	char *pBeginning = p;
	while (*p != 0) { ++p; }
	char *pEnd = p;
	p = pBeginning;
	while (p < pEnd)
		*p = 0;
		++p;
I am thinking that the second sample may be more efficient, because the length of the second loop is known before it starts and the CPU can parallelize it. In the first sample parallelization is never possible because the length of the loop cannot be known in advance. Is this thinking correct?
Labels (2)
jimdempseyatthecove
Black Belt
Right, not only because of length known vs parallelization, but also it removes the requirement to read the destination array.
Knowing the length of the ray seams a requirement for vectorization of the first loop, but it is not necessarily a requirement.
loop:
   read a vector worth of data
   if any are zero exit loop
   zero vector worth of data
 end loop
zero lanes of vector until 1st lane with 0
Jim Dempsey
jimdempseyatthecove
Black Belt
loop:
 end loop
Jim Dempsey
AbhishekD_Intel
Thanks for accepting the solution. We are no longer monitoring this thread. Please post a new thread if you have any issues.
Warm Regards,
Abhishek
