Intel® C++ Compiler
Is there a way to obtain NASM code from a C-like language?
Andrew_F_
I need to implement an optimized Algorithm in NASM, unfortunately is a bit difficult for me since I'm new to its syntax. So I'm looking for a way to translate a C program in NASM.
Any tool or suggestion to help me?
Bernard
Valued Contributor I
The only method I suppose is to look at C program disassembly and try to translate it manually to NASM syntax.
KitturGanesh
Yes, there's no other way know of other than deciphering the c assembly and convert to nasm accordingly....
Regards, Kittur
Bernard
For simple programs or  functions it is quite beneficial for understanding the assembly implementation.
