Intel® C++ Compiler
7838 Discussions
Issue with IntelMPI/Intel Compilers and SpecMPI
viennej
I am experimenting an issue on the cluster with SpecMPI using Intel Compilerv12 / Intel MPI.
Description of the Cluster:
Network: Mellanox IB-QDR
Node: 2 x Intel Xeon E5640 with 12 GB memory
MPI: Intel MPI v4.0.2.003
OFED: 1.5.1
Compiler Intel v11 and Intel v12
I am running SpecMPI on 64 cores using the command:
mpiexec.hydra -f hosts-intel -n $ranks -perhost=8 ....
CC = mpiicc
CXX = mpiicpc
FC = mpiifort
CPP = mpiicpc
Description of the problem:
When I use the Intel Compiler v12 (12.0.3), using the following compilation flags inside the config file of SpecMPI for 104.milc and 130.socorro:
COPTIMIZE = -O3 -xSSE4.2 -no-prec-div
FOPTIMIZE = -O3 -xSSE4.2 -no-prec-div
The results of 104.milc are incorrect. All the rest is ok.
If I use the Intel Compiler v11 (11.1.069).
All the results are correct.
Removing the compilation flag -xSSE4.2 resolved the issue but created a new one.
Using the compilation flags inside the config file of SpecMPI :
COPTIMIZE = -O3 -no-prec-div
FOPTIMIZE = -O3 -no-prec-div
With Intel Compiler v12 (12.0.3), all is running fine except Socorro that crashed
With Intel Compiler v11 (11.1.069), all is running fine without any problem.
I was wondering if you were aware of this issue or you were able to reproduce it.
I don't know if the issue is coming from Compiler12, Spec benchs or Intel MPI + compiler v12.
Dmitry_K_Intel2
Hi viennej,
I would say that this is a compiler issue. You didn't change MPI version - you only used different compilers.
I would move this topic to the C/C++ compiler forum.
Regards!
Dmitry
viennej
Hi Dmitry,
Ok ,
Jerome
viennej
Have you been able to reproduce it ?
Thx,
Jerome
viennej
FYI, I found the reason of the issue. I am posting here to inform everybody.
SPEC had to update the validation file for 104.milc due to compiler Intel compiler v12. So, you need to use the last version of Spec MPI (2.0.1) when you want to run Spec MPI with Intel compiler 12.
Thx,
Jerome
