Intel® C++ Compiler
7876 Discussions
Issue with static_cast and decltype
H_K_
The following code fails to compile with Intel C++ 17.0 but compiles fine with MSVC & gcc. If I use a typedef instead of decltype, then it compiles OK.
#include <iostream>
template<class Sig, Sig Func> struct MyFunc;
template<class T, class... Args, void (T::*Func)(Args...) const>
struct MyFunc<void (T::*)(Args...) const, Func>
  static void execute(const T *obj, Args... args)
    (obj->*Func)(args...);
template<class T, class... Args, void (T::*Func)(Args...)>
struct MyFunc<void (T::*)(Args...), Func>
  static void execute(T *obj, Args... args)
#define MYFUNC(...) MyFunc<decltype(__VA_ARGS__), __VA_ARGS__>
struct A
  void func() const { std::cout << "in A::func() const" << std::endl; }
  void func() { std::cout << "in A::func()" << std::endl; }
int main()
  A a;
  MYFUNC(static_cast<void(A::*)() const>(&A::func))::execute(&a);
  MYFUNC(static_cast<void(A::*)()>(&A::func))::execute(&a);
Viet_H_Intel
What GCC version and the command line options did you use?
H_K_
This is compiling with the following compilers:
  • gcc 6.3.0 (with no special compilation flags, or with -std=c++11)
  • Visual Studio 17.0 (with no special compilation flags)
It is failing with Intel 19.0 Update 3 (Windows) with /Qstd=c++14 but seems to work with /Qstd=c++17.
