Intel® C++ Compiler
Issues With Warnings
Scott_Danahy
I've encoundered two issues with Intel Composer XE 2011 Update 10 integrated with Visual Studio 2010 SP1.
I compile the following code with /W4 and /WX:
#include
#pragma warning( push )
#pragma warning (disable: 2415)
static const char * Label= "LABEL"; //warning #2415: variable "Label" of static storage duration was declared but never referenced
#pragma warning( pop )
int main(void)
unsigned count=10;
for(int i=0;i
printf("%d\\n",i);
return 0;
A warning is trigged for the "const char * Label" line even though it has been disabled betwen a push and pop. Much more seriously, the /WX flag has no effect and the file is compiled without the warnings being treated as errors. The 'for' line produces a warning as expected but it is not trated as an error.
By comparison, the Microsoft (v10) compiler produces a "warning treated as error - no 'object' file generated with the /WX flag enabled.
Thank you,
Scott
Judith_W_Intel
As for the first issue (why the 2415 is not disabled). You'll notice if you remove the #pragma warning (pop) the warning is disabled. The compiler does not actually issue the warning until the end of the file (when it can actually tell the Label was never referenced). At that point the warning stack has been popped by the #pragma warning (pop). So unfortunately this specific warning cannot be disabled by putting push/pop around the declaration.
Judith_W_Intel
As for the second issueit looks like you need to use /Werror-all instead of /WX if you want the remarks that come out with the /W4 option to be treated as errors.
This is what the help says:
/WX force warnings to be reported as errors
/Werror-all
force warnings and currently enabled remarks to be reported as errors
Judy
Scott_Danahy
Makes sense, thanks getting back to me.
Scott
Scott_Danahy
I added "/Werror-all" and build the sample code above. The warnings are still not reported as errors. Is there something else I need to do?
Scott
Om_S_Intel
For me warnings and remarks are reported as errors.
c:\forum\U106251>type tstcase.cpp
#include
int main(void)
unsigned count=10;
for(int i=0;i
gned operands
printf("%d\n",i);
return 0;
c:\forum\U106251>icl -c -W4 -Werror-all tstcase.cpp
Intel C++ Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.1.258 Build 20111011
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
tstcase.cpp
tstcase.cpp(9): error #2557: comparison between signed and unsigned operands
for(int i=0;i
tstcase.cpp(4): error #2415: variable "Label" of static storage duration was declared but never referenced
compilation aborted for tstcase.cpp (code 2)
c:\forum\U106251>icl -V
icl: command line warning #10155: ignoring option '/V'; argument required
icl: command line error: no files specified; for help type "icl /help"
Scott_Danahy
I think I see. I mixed /WX-Werror-all. The /WX option seems to override /Werror-all.
