As for the first issue (why the 2415 is not disabled). You'll notice if you remove the #pragma warning (pop) the warning is disabled. The compiler does not actually issue the warning until the end of the file (when it can actually tell the Label was never referenced). At that point the warning stack has been popped by the #pragma warning (pop). So unfortunately this specific warning cannot be disabled by putting push/pop around the declaration.
As for the second issueit looks like you need to use /Werror-all instead of /WX if you want the remarks that come out with the /W4 option to be treated as errors.
This is what the help says:
/WX force warnings to be reported as errors
/Werror-all
force warnings and currently enabled remarks to be reported as errors
Judy
For me warnings and remarks are reported as errors.
c:\forum\U106251>type tstcase.cpp
#include
#pragma warning( push )
#pragma warning (disable: 2415)
static const char * Label= "LABEL"; //warning #2415: variable "Label" of static
storage duration was declared but never referenced
#pragma warning( pop )
int main(void)
unsigned count=10;
for(int i=0;i
gned operands
printf("%d\n",i);
return 0;
c:\forum\U106251>icl -c -W4 -Werror-all tstcase.cpp
Intel C++ Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.1.258 Build 20111011
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
tstcase.cpp
tstcase.cpp(9): error #2557: comparison between signed and unsigned operands
for(int i=0;i
tstcase.cpp(4): error #2415: variable "Label" of static storage duration was declared but never referenced
static const char * Label= "LABEL"; //warning #2415: variable "Label" of static storage duration was declared but never referenced
compilation aborted for tstcase.cpp (code 2)
c:\forum\U106251>icl -V
icl: command line warning #10155: ignoring option '/V'; argument required
icl: command line error: no files specified; for help type "icl /help"
