Intel® C++ Compiler
Itanium C++ Compiler for Linux
Karel_Gardas
I'm looking for Linux Intel C++ compiler for Itanium architecture, but cannot find any. So far I've just found compilers for IA-32 and Intel64/AMD64/EM64T but not for IA64. Any idea where is it located?
Karel
Kevin_D_Intel
The latest Itanium compiler is 11.1 Update 8 (11.1.075) and is available from the Intel Registration Center.
After logging in, click on the version appearing in Download latest Update column corresponding to the Intel C++ Composer XE for Linux* and then use the Release and Update (Build #) pull-downs to select, 11.1 Update 8.
The Itanium download package (l_cproc_p_11.1.075_ia64.tgz) is under the Product for IA-64 link.
JLuna5
hi, if don't run good how you want, you can to install wine and install is as if you be executed in windows...
