Intel® C++ Compiler
Jumping to Labels in Inline Assembly
Elbert_John_A__Orozc
Can I use labels in inline assembly such as this:
int main()
        __asm__(
                      "jmp label_1;"
        label_1:
        return 0;
Mine doesn't seem to compile somehow...
jimdempseyatthecove
Use Intel form of assembler:
        __asm {
                      jmp label_1;
        label_1:
Jim Dempsey
SergeyKostrov
Valued Contributor II
I assume this is AT&T style of inline assembler and did you have an error like this one: ... ..\Tests>g++ Test.cpp ..\Temp/ccqWaaaa.o(.text+0x2b):Test.cpp: undefined reference to `label_1' collect2: ld returned 1 exit status ...
Thanks jim. It's something like that but I wish to write it in AT&T format.
Yes Sergey, I can't seem to find the right format/syntax using AT&T (@.@)
SergeyKostrov
Please take a look at another thread with a similar problem: Forum Topic: Jump labels in inline assembler Web-link: http://software.intel.com/en-us/forums/topic/386259
jimdempseyatthecove
Sergey,
Elbert was trying to jump from within an assembler block to a lable declared in C/C++ code.
Numeric lables appear to work. This works:
[cpp]
int main()
  __asm__(
                      "jmp 1;"
     label_1:
  __asm__("1:");
        return 0;
[/cpp]
Awkward, but works.
Jim Dempsey
Thanks! but then when I tried to check by printf:
int main()
{    __asm__(
                    "jmp 1;"
     printf("This must not appear!");
     __asm__("1:");
return 0;
It seems that it doesn't jump.... (T.T)
Casey
Elbert,
Try using a label that starts with a letter and see if that works.  I tried code like your and Jim's which icc and gcc would compile but would segfault at the jmp.  Swapping 1: for label1: fixed that for me.  For reference, here is the code I compiled:
[cpp]
 int main()
 printf("Before jmp\\n");
 __asm__("jmp label1;");
 printf("This must not appear\\n");
 __asm__("label1:");
 printf("After jmp\\n");
 return 0;
[/cpp]
This is the relevant assembler produced with the -S flag:
[cpp]
 ..B1.2: # Preds ..B1.7
 # Begin ASM
 # Begin ASM
 jmp label1;
 # End ASM #6.0
 # End ASM
 # LOE rbx r12 r13 r14 r15
 ..B1.8: # Preds ..B1.2
 movl $.L_2__STRING.1, %edi #7.4
 xorl %eax, %eax #7.4
 ..___tag_value_main.10: #7.4
 call printf #7.4
 ..___tag_value_main.11: #
 ..B1.3: # Preds ..B1.8
 # Begin ASM
 # Begin ASM
 label1:
# End ASM #8.0
# End ASM
[/cpp]
The compiler command line:
[bash]
$ icc --version
icc (ICC) 13.1.3 20130607
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
$ icc -o asmtest asmtest.c
[/bash]
and the output:
[bash]
$ ./asmtest
Before jmp
After jmp
[/bash]
and finally the relevent disassembly in idb (from a build with -g)
[bash]
asmtest.c:6 __asm("jmp label1;");
0x00000000004005C1 eb 15 jmp 0x4005d8 <main+0x34>
asmtest.c:7 printf("This must not appear\\n");
0x00000000004005C3 b8 f8 06 40 00 mov eax, 0x4006f8
0x00000000004005C8 48 89 c7 mov rdi, rax
0x00000000004005CB b8 00 00 00 00 mov eax, 0x0
0x00000000004005D0 e8 cb fe ff ff call 0x4004a0 <_init+0x28>
0x00000000004005D5 89 45 f4 mov dword ptr [rbp-0xc], eax
asmtest.c:9 printf("After jmp\\n");
0x00000000004005D8 b8 10 07 40 00 mov eax, 0x400710
[/bash]
If I use the purely numeric labels you and Jim used, the jmp assembler is translated into
[bash]
0x00000000004005B9 e8 e2 fe ff ff call 0x4004a0 <_init+0x28>
[/bash]
which results in the segfault I mentioned at the top of my post.  For reference, that address in that call instruction is in no-mans land.
SergeyKostrov
>>...Elbert was trying to jump from within an assembler block to a lable declared in C/C++ code. What about some compromise ( split assembler blocks if it is possible ) like as follows: // Test034.cpp // http://software.intel.com/en-us/forums/topic/404730 // http://software.intel.com/en-us/forums/topic/386259 #include "stdio.h" int main( void ) { // Test-case 1 /* __asm__ ( "jmp label_1;" ); label_1: */ // Test-case 2 ///* printf( "Test started\n" ); void *pvAddress = NULL; __asm__ ( "prefetcht0 %0;" : : "m" ( pvAddress ) ); goto label_2; printf( "That message should never be shown - 1\n" ); label_2: __asm__ ( "prefetcht0 %0;" : : "m" ( pvAddress ) ); goto label_3; printf( "That message should never be shown - 2\n" ); label_3: //*/ printf( "Test completed\n" ); return ( int )0; } Of course, some restrictions are possible ( complexity of codes dependant ) but at least the Test-case 2 works.
SergeyKostrov
Source code for the test is attached and output is as follows: ..\Tests>g++ Test034.cpp ... ..\Tests>a.exe Test started Test completed
jimdempseyatthecove
Casey,
On the version of ICC that I use (2011.9.300), I can use 1:, but not label1:.
I am compiling under Windows with __asm__ (AT&T).
** in running, the jump to address is incorrect (bug in ICC)
Jim Dempsey
Casey
Jim,
Interesting differences between platforms.  As far as i know on windows inline asm is assembled by icc and on linux inline asm is assmebled by "as" (the GNU assembler).
After some testing, I can use (in linux)  the purely numberic lables if I specify the jump as "jmp 1f;", which jumps to the 1: label in the forward direction.
Thanks guys for the replies... by the way, I'm using intel c++ compiler 2013 in windows on Visual Studio 2012
The attached code by Sergey doesn't seem to compile ....
Casey's code doesn't seem to compile with word labels ......... (T.T)
After trying out suggestions and playing with the code, this seem to work:
int main()
     printf("let's try this!\n");
     __asm__("mov $0x01, %al;"
                     "cmp $0x00, %al;");
      __asm{jne wee};
      printf("This must not appear!\n");
      wee:
      printf("Done!\n");
      system("PAUSE");
But then I tried it with a combination of AT&T and Microsoft Style Syntax .... I wish having it in pure AT&T/GNU style assembly .... (@.@)
@Jim: Is it really a bug in Intel C++ Compiler?
SergeyKostrov
You've posted AT&T style inline assembler in the initial post and since Intel C++ compiler is compatible with Microsoft C++ compiler the test case can not be compiled. Since you've finally informed us that you're using Intel C++ compiler I could inform you that jumping functionality from inline assembler to C/C++ codes is supported and I verified it with three C++ compilers: ... // icl.exe Test034.cpp - Compiled ( Intel ) // cl.exe Test034.cpp - Compiled ( Microsoft ) // bcc32.exe Test034.cpp - Compiled ( Borland ) ... For example, a file with assembler codes generated by Borland C++ compiler is attached.
SergeyKostrov
Duplicate - Removed
Casey
The assembler I posted was produced by icc (I was not calling the c++ compiler) with the -S flag and does assemble in Linux.  As noted in my earlier post, differences in assembling inline asm between platforms is causing confusion with examples working for some but not all.  It has already been established (by Jim) that the code I posted does not work in windows, but the intel compiler in linux will compile and it does work there.
SergeyKostrov
It was already explained by Elbert that Intel C++ compiler version 2013 integrated with VS 2012 under Windows was actually used. Even if initial test-case created some confusion I don't think that Elbert is interested in Linux, GCC and AT&T style of inline assembler. Elbert, am I correct?
Marián__VooDooMan__M
New Contributor II
Sadly, ICC does not have (as topic name/title suggests) inline assembly jumps implemented. Consider following snippet:
--- snip ---
  __asm__ __volatile__
    ("MULT_M_sse3_single:     \n\t"
     "mov    %0, %4           \n\t" // save %0(oL)
     // float tL0 = oL[0] + iL[0] * fL[0];
     // float tL1 = oL[1] + iL[1] * fL[1];
     "movaps (%1), %%xmm1     \n\t"
     "mulps  (%2), %%xmm1     \n\t"
     "addps  (%0), %%xmm1     \n\t"
     // TODO: Storing float[2] to 64bit MMX register is not a good idea.
     "movdq2q %%xmm1, %%mm0   \n\t" // save float[2] to mm0
     // loop
     "MULT_M_sse3_single_loop:\n\t"
     "prefetchnta 0x80(%1)    \n\t"
     "movaps     (%1), %%xmm0 \n\t" // xmm0,1,3,2
     "movaps 0x10(%1), %%xmm4 \n\t" // xmm4,5,7,6
     "add    $0x20, %1        \n\t"
     "prefetchnta 0x80(%2)    \n\t"
     "movsldup (%2), %%xmm1   \n\t"
     "movshdup (%2), %%xmm3   \n\t"
     "movsldup 0x10(%2), %%xmm5 \n\t"
     "movshdup 0x10(%2), %%xmm7 \n\t"
     "add    $0x20, %2        \n\t"
     "add    $0x20, %0        \n\t"
     "pshufd $0xb1, %%xmm0, %%xmm2 \n\t"
     "pshufd $0xb1, %%xmm4, %%xmm6 \n\t"
     "mulps  %%xmm1, %%xmm0   \n\t"
     "mulps  %%xmm5, %%xmm4   \n\t"
     "prefetcht2 0x80(%0)     \n\t"
     "addps  -0x20(%0), %%xmm0 \n\t"
     "addps  -0x10(%0), %%xmm4 \n\t"
     "mulps  %%xmm3, %%xmm2   \n\t"
     "mulps  %%xmm7, %%xmm6   \n\t"
     "addsubps %%xmm2, %%xmm0 \n\t"
     "addsubps %%xmm6, %%xmm4 \n\t"
     "dec    %3               \n\t"
     "movaps %%xmm0, -0x20(%0)\n\t"
     "movaps %%xmm4, -0x10(%0)\n\t"
     "jne    MULT_M_sse3_single_loop \n\t"
     "MULT_M_sse3_single_save: \n\t"
     // oL[0] = tL0;
     // oL[1] = tL1;
     "movq2dq %%mm0, %%xmm1   \n\t" // restore float[2] from mm0
     // EMMS takes approximately 58 clocks extra.
     "emms                    \n\t"
     "movlps %%xmm1, (%4)     \n\t" // restore float[2]
     : "q"(oL), "q"(iL), "q"(fL), "r"(n/4), "r"(soL)
     : "memory");
  return;
--- snip ---
ICC choackes with error saying jumps in inline assembly is not implemented. At premier support they told me it will not be implemented (at least in near future). G++ does not have any problem with this snippet.
New Contributor II
--- snip ---
     // loop
     "dec    %3               \n\t"
     // oL[0] = tL0;
     // oL[1] = tL1;
     "emms                    \n\t"
     : "memory");
  return;
--- snip ---
ICC chokes with error saying jumps in inline assembly is not implemented. At premier support they told me it will not be implemented (at least in near future). G++ does not have any problem with this snippet.
New Contributor II
--- snip ---
[cpp]
     // loop
     "dec    %3               \n\t"
     // oL[0] = tL0;
     // oL[1] = tL1;
     "emms                    \n\t"
     : "memory");
  return;
[/cpp]
--- snip ---
ICC chokes with error saying jumps in inline assembly is not implemented. At premier support they told me it will not be implemented (at least in near future). GCC does not have any problem with this snippet.
IIRC it chokes at line #02 (the jump label)
MSVC 2012, ICC 13 (the latest update), Windows 8 x64, x64 build target
