Ive just do it a migration from CVF application to IVF, for EM64T, when I did the debug version of the project there arent problems, but when I want do the release version, I obtain the next message:
LNK1112: module machine type 'AMD64' conflicts with target machine type 'X86'
All the libraries that I use in the project there were migrated to EM64T within setting in the section:
PROPERTY PAGES -> LINKER -> ADVANCE -> TARGET MACHINE -> No Set,
In addition, I am sure that all the library, as well as the project there was built whit the same (debug and release) options.
I cannot send you a test case because when I do a simple case it works but in the context of this project I does not work L
I work like this graphic
Cesar
That's the message you get when you don't pass the /machine:amd64 flag to the linker.
