Could youre-post a complete compilationlog( C++ compiler& Linker ) in text format, please?
Here are results of my investigation:
1.I searched in the log file for a substring 'error C'and I found a couple of compilation errors:
checking for pthread_create in -lpthreads... dummy.c
dummy.c(2) : fatal error C1083: Cannot open include file: 'pthread.h': No such file or directory
no
checking for pthread_create in -lpthread... dummy.c
no
checking for pthread_create in -lc_r... dummy.c
no
checking for pthread_create in -lc... dummy.c
no
However, I don't think thatthese errors arerelated to your linking problem. Personally, I would look at 'dummy.c'.
2. There are lots of linker errors at the end of the log file:
c:/mozilla-build/python/python2.7.exe
/c/Users/Alex/Downloads/mozilla-beta/js/src/config/pythonpath.py
-I../config /c/Users/Alex/Downloads/mozilla-beta/js/src/config/expandlibs_exec.py
--uselist -- xilink -NOLOGO -OUT:js.exe -PDB:js.pdb
-MACHINE:X64 -opt:ref,icf
../../../dist/lib/mozglue.lib
-> js.obj
-> jsworkers.obj
-> jsoptparse.obj
-> jsheaptools.obj
c:/Users/Alex/Downloads/objdir/dist/lib/nspr4.lib
c:/Users/Alex/Downloads/objdir/dist/lib/plc4.lib
c:/Users/Alex/Downloads/objdir/dist/lib/plds4.lib
-> ../js_static.lib
kernel32.lib
user32.lib
gdi32.lib
winmm.lib
wsock32.lib
advapi32.lib
psapi.lib
xilink: executing 'link'
Creating library js.lib and object js.exp
js_static.lib(jsapi.obj) : error LNK2019: unresolved external symbol
-> "enum JSType __cdecl js::TypeOfValue(struct JSContext *,class JS::Value const &)"
(?TypeOfValue@js@@YA?AW4JSType@@PEAUJSContext@@AEBVValue@JS@@@Z)
-> referenced in function JS_TypeOfValue
First unresolved external symbol is detectedin JS_TypeOfValue function andyou need to understand what is
wrong withjs::TypeOfValue method.Whereisthe implementation? Inwhat source file?
I also marked with '->' and bolded all modules for your review.
I crossed all libraries you could ignore.
I could assume that:
some source file is missing, or
a piece of code is not included in compilation because it was #ifdef-ed improperly
( some macro was not definedor defined )
Sergey
I don't know so far.
Could you upload 'jsapi.h', 'jsapi.cpp' and a header where a macro 'JS_PUBLIC_API' is declared, please?
Ireviewed these source files and I don't see any problems. This is what I would do to verify some macros:
UPDATE #1
>> jstypes.h <<
* The linkage of JS API functions differs depending on whether the file is
* used within the JS library or not. Any source file within the JS
* interpreter should define EXPORT_JS_API whereas any client of the library
* should not. STATIC_JS_API is used to build JS as a static library.
#if defined( STATIC_JS_API )
# pragma message ( "*** Message: STATIC_JS_API defined ***" )
# define JS_PUBLIC_API(t) t
# define JS_PUBLIC_DATA(t) t
#elif defined( EXPORT_JS_API ) || defined( STATIC_EXPORTABLE_JS_API )
# pragma message ( "*** Message: EXPORT_JS_API or STATIC_EXPORTABLE_JS_APIdefined ***" )
# define JS_PUBLIC_API(t) MOZ_EXPORT_API(t)
# define JS_PUBLIC_DATA(t) MOZ_EXPORT_DATA(t)
#else
# pragma message ( "*** Message: JS API functions declared asIMPORTED ***" )
# define JS_PUBLIC_API(t) MOZ_IMPORT_API(t)
# define JS_PUBLIC_DATA(t) MOZ_IMPORT_DATA(t)
#endif
Please update 'jstypes.h' source file,re-build the project and submit a compilation log. Thank you.
Sergey
I just completed a review and noticed thatyour buildbreaks on compilation.
You havesome compilation errors now.Simply to note, you hadsome linker errors.
Please take a look at some consolidated pieces of my review...
Sergey
PS: Alex, you've escalated your problems because you've done a change from Beta 4 to Beta 5. I wouldn't do it until
the investigation with the linker problems is completed. Look, now thetitle of thepost doesn't reflect your current problems.
Anyway, I'm ready to help as much as possible...
Here is a list of all compilation errors ( Detailed ):
dom_quickstubs.cpp
*** Message: JS API functions declared as IMPORTED ***
..\include\mozilla/CheckedInt.h(355): error: type name is not allowed
bool IsSigned = IsSigned
..\include\mozilla/CheckedInt.h(355): error: the global scope has no "value"
..\include\mozilla/CheckedInt.h(361): error: a template argument list is not allowed in a declaration of a primary template
struct IsMulValidImpl
..\include\mozilla/CheckedInt.h(372): error: a template argument list is not allowed in a declaration of a primary template
..\include\mozilla/CheckedInt.h(396): error: a template argument list is not allowed in a declaration of a primary template
..\include\mozilla/CheckedInt.h(421): error: type name is not allowed
template
..\include\mozilla/CheckedInt.h(421): error: the global scope has no "value"
template
..\include\mozilla/CheckedInt.h(427): error: a template argument list is not allowed in a declaration of a primary template
struct OppositeIfSignedImpl
..\include\mozilla/CheckedInt.h(408): error: identifier "IsMulValidImpl" is undefined
return IsMulValidImpl
detected during:
instantiation of "bool mozilla::detail::IsMulValid(T, T) [with T=unsigned int]" at line 690
instantiation of "mozilla::CheckedInt
[with T=uint32_t={unsigned int}]" at line 1107 of "../../../dist/include/WebGLContext.h"
..\include\mozilla/CheckedInt.h(408): error: type name is not allowed
detected during:
..\include\mozilla/CheckedInt.h(408): error: the global scope has no "run"
detected during:
compilation aborted for c:/Users/Alex/Downloads/objdir/js/xpconnect/src/dom_quickstubs.cpp (code 2)
Here is a consolidation of all compilation errors ( By Error ):
Here is a consolidation of all declarations that cased some compilation errors ( By Declaration ):
template
template
Could you try to create a simple test-case that reproduces at least some compilation error? I think it will help Intel Software Engineers to
understand what could be possibly wrong.
Sergey
(It's the same thing you need to change in both files).FROM:
elif test "$_CC_MAJOR_VERSION" = "17"; then
_CC_SUITE=11
TO:
elif test "$_CC_MAJOR_VERSION" = "13"; then
_CC_SUITE=10
