I'm trying to compile Firefox for Windows using the Intel compiler. I've managed to compile everything fine up until this point:
http://i44.tinypic.com/3010vue.png
From what I've gathered/been told, multiple copies of the CRT are being linked. I've tried setting the library to be used as the one given in -LIBPATH:C:\\Intel\\Composer XE 2011 SP1\\compiler\\lib\\intel64
but MINGW32 doesn't deal well with spaces and keeps returning errors.
So that didn't work. I'm not quite sure what else I can do?
If it helps I'm using the 30 day trial of Intel Composer XE 2011 SP1 Update 7.
- « Previous
- Next »
Quoting xunxun
It's strange.
pcxfirefox is my one project, and I use my wiki guide to build firefox 10 successfully.
Thanks for the response and as you can see this is a long story.
What ICL version do you use?
It seems it's 12.1.2.278 in my wiki, I think it's icc12 update8.
I have built the edition some days ago, so I forgot it ...
Alex had a couple of Linker errors, like:
- LNK1169 - One or more multiply defined symbols found
- LNK4098 - Defaultlib 'library' conflicts with use of other libs; use /NODEFAULTLIB:library
- LNK2005 - Symbol already defined in object
Note: Take a lookat aPost #33.
What do you think?
Did you make any changes in make files,in environment variables, etc?
Sergey
What do you think?
Sergey
Quoting Sergey Kostrov
What do you think?
Sergey
What do you think?
Sergey
No, I have not encounted it.
I only modify like https://code.google.com/p/pcxfirefox/wiki/MozillaBuiltICC#Step_1_Patch_start-msvc_.bat and https://code.google.com/p/pcxfirefox/wiki/MozillaBuiltICC#Step_2_Patch_Mozilla_source_Makefile
I have no idea how the issues came out.
If you give me all output information, maybe I will find it out.
Quoting xunxun
...If you give me all output information, maybe I will find it out.
Sorry, I wassimply helping 'Alexboy94' to resolve some linking issues and the same applies to many other
users responded to his initialpost. I hope hewill respond ifinterested.
Sergey
- « Previous
- Next »
