today, i am working on a program which works perfect before.
But when i run it now, there is such bug report.
OMP: Warning #2: Cannot open message catalog "2052\\libiomp5ui.dll"
it is also strange that the console language changes to Janpanese, which i don't want to.
I am not sure what happens with the environment.
This is a known bug and is fixed. But the fix is not available now. It should be in the next coming update 6.
In "Debug" build you may have some msg to output. In this case the omp runtime will look for the matching text to display. If you have Japanese locale settting, it will be looking for 1041 subfolder and if no such subfolder exists, it displays this msg.
There are several work-arounds for this. See this article about it.
Jennifer
I have tried in release mode, it works at least without error message,
but in debug mode
it always report the error message.
OMP: Warning #2: Cannot open message catalog "2052\libiomp5ui.dll":
OMP: System error #126: The specified module could not be found.
OMP: Info #3: Default messages will be used
I don't know if if any one has the experience about the problem, thank you very much in advance!
Jennifer
