I purchased the Parallel Studio XE C++ for OSX on 8/5/2015. After installing XCode 7.0 I copied the contents of /Library/Application Support/Developer/6.4/XCode/Plug-ins to /Library/Application Support/Developer/7.0/XCode/Plug-ins to have access to the Intel compiler.
I'm now getting a license not available error:
Error: A license for Comp-CM is not available (-5,357). Make sure that a license file is being used that contains a license for the requested feature. If your license requires a license server, make sure that the server is using the right license file (usually, this would be the same license file that is being used by this application), and make sure that you have not changed the license file since starting the server. License file(s) used were (in this order): 1. Trusted Storage ** 2. /usr/bin/icc-16.0.083-base/bin/intel64/../../Licenses ** 3. /Users/demo/Licenses ** 4. /opt/intel/licenses ** 5. /Users/Shared/Library/Application Support/Intel/Licenses/license_ism2_85V_LG7R-RN54M8X2.lic ** 6. /Users/Shared/Library/Application Support/Intel/Licenses/license_ism2_GLK_LG7R-RN54M8X2.lic ** 7. /Users/Shared/Library/Application Support/Intel/Licenses/license_ism2_W4F_LG7R-RN54M8X2.lic ** 8. /Users/Shared/Library/Application Support/Intel/Licenses/m_RN54M8X2.lic ** 9. /usr/bin/icc-16.0.083-base/bin/intel64/*.lic Please visit http://software.intel.com/sites/support/ if you require technical assistance. icc-16_0_083: error #10052: could not checkout FLEXlm license Command /usr/bin/icc-16.0.083 failed with exit code 1
Also, when clicking the "Register and Download" button in the email I received when I purchased the software, I get the error "Serial Number is no longer valid".
I also tried reinstalling the software (successfully) but it didn't solve the problem.
Dave
This might be handled more expeditiously on the companion forum on registration and licensing.
Hi Tim,
I posted on the registration and licensing forum.
Dave
Dave, I see that you've also posted in the Download/Registration/Licensing forum (the right place) and Devorah is addressing it *(has requested the serial number). You can respond to it in that forum for resolution, appreciate much.
_Kittur
