Intel® C++ Compiler
7833 Discussions
Link error "undefined symbol" when using some cmath functions with interprocedural optimisation
Sebastien_B_1
My setup: VS2017, Intel C++ Compiler 2021 (OneAPI base toolkit 2021.2)
Hi all,
When I try to compile an application the uses acosh or cbrt from cmath (and probably other cmath functions), it works when interprocedural optimisation is disabled.
If I set Interprocedural optimisation to "Multi-File (/Qipo)", I get undefined symbol error:
1>lld-link: : error : undefined symbol: __declspec(dllimport) __svml_acosh32
1>lld-link: : error : undefined symbol: __declspec(dllimport) __svml_acosh64
Here is a minimal example:
#include <iostream>
#include "cmath"
int main() {
  std::cout << "success " << std::acosh(2.0) << std::endl;
  return 0;
It seems like a bug. Any idea?
ShivaniK_Intel
We are unable to reproduce the error at our end with the same version of the OneAPI Base Toolkit. Could you please provide your vsx project file so we can check the configuration and debug it?
Thanks & Regards
Shivani
Sebastien_B_1
Thanks for your reply.
See attached a complete project that fails on my side. Note that it fails in Release mode.
ShivaniK_Intel
Hii,
We are able to reproduce the error on our end. We are working on it and will get back to you soon.
Thanks&Regards
Shivani
Viet_H_Intel
Can you try with the latest oneAPI to see if the issue is resolved?
Viet_H_Intel
Looks like this issue no longer reproduces in oneAPI. Thus, we are going to close this thread.
If you need anything else, please create a new one.
