Intel® C++ Compiler
Link error
lsheva
I am using Intel compiler (11.1\\0.65)on 64-bit machine.
While building a certain project, I receive the following error:
error LNK2019: unresolved external symbol "__declspec(dllimport) public: bool __cdecl recordingsimulation::AbsDataSource::MoveToNextFile(void)" (__imp_?MoveToNextFile@?$AbsDataSource@PEAX$0PPPPPPPP@@recordingsimulation@@QEAA_NXZ) referenced in function "private: void __cdecl MessageHandler::HandleACLInputError(void)" (?HandleACLInputError@MessageHandler@@AEAAXXZ)
When compiling in win32 it builds fine, but in the x64 configuration it fails.
I switched to the visual c++compiler and the build succeeded.
Most of the methods in the class are virtual, but the specific method it doesn't find isn't (MoveToNextFile).
When I declared it as virtual the problem was solved and the build succeeded, but it shouldn't be virtual.
Do you have any idea why the Intel compiler doesn't "see" the symbol?
Maybe I should turn on some flags?
I don't want to leave the virtual as now.
Thank you,
Liad.
vetroxl
Have checked that your directories are the same for x64 config? I had the same problem once and had to add all my include and lib dirs in the x64 config.
Mark_S_Intel1
Not clear what the issue is without a test case. Can you send a test case that we can use to reproduce the problem?
There's is also the the 11.1.067 compiler available in case you would like to try and see if it resolves the issue.
--mark
Alexander_C_Intel
Hi Liad,
What configuration do you use for the project?
If it is Release could you try Debug. Or simply try reducing optimization level.
Alex
JenniferJ
Yes, please try not use /Qipo.
But it is still a compiler bug. Is it possible to send the testcase in private post? Or please use Premier Support - https://premier.intel.com/
Jennifer
