We are building our VC++ projects with Intel C++ Compiler. But we are getting many LINKER errors, the same projects build without any errors with Microsoft VC++ Compiler.
ipo_61246obj.obj : error LNK2001: unresolved external symbol "class UniqueId const Meta::ModelId" (?ModelId@Meta@@3VUniqueId@@B)
ipo_61246obj.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __cdecl Log::LogMsg(int,unsigned short const *,...)" (__imp_?LogMsg@Log@@QAAXHPBGZZ)
ipo_61246obj.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __thiscall UniqueId::From(unsigned short const *)" (__imp_?From@UniqueId@@QAEXPBG@Z)
Any idea why this is happening?
Komal
Komal
1st of all, please use the latest compiler update.
For 1st link error, try build without /Qipo and see if it goes away. if so, it's a bug in IPO.
For 2nd and 3rd, try to build the dll project without /Qipo.
To disable /Qipo:
1. open project property, under C++/Optimization, set Interprocedual Optimization to "NO"
2. under Linker/Optimization, set Interprocedual Optimization to "NO"
To disable /Qipo:
As for the DLL project, make sure to use "__declspec(dllexport)" for exporting any symbols.
The .def is used only at link-time and icl optimizes as much as possible, so the symbol may not exist at link time.
Jennifer
Hi Jennifer,
I am using "Intel C++ Compiler 10.0 for Windows" version.
I cannot find the option "/Qipo" in the Command Line of C++ and Linker settings (in my project).
Also i can't find a setting related to "Interprocedural Optimization" in my prject proerties. Is it because i have an older version of Intel C++ Compiler?
Komal
Komal
Yes, please try the latest 10.1.029 or 11.1.066.
Hi Jennifer,
From where can i download Intel C++ Compiler versions 10.1.029?
I could only locate the download page for version11.1.066 (http://www.intel.com/cd/software/products/asmo-na/eng/368972.htm, which supposedly has a bug in IPO (http://software.intel.com/en-us/forums/showthread.php?t=62095) . I don't want to run into Linker Errors again, even after downloading and installing another version.
I already have an evaluation copy of 10.0 version running on one of my systems, can i update the same ro use 10.1.029 or 11.1.066 (does the evaluation version have installation restrictions?)
Komal
Komal
Quoting - Jennifer Jiang (Intel)
I used the latest version of Intel C++ Compiler 11.0.072, and the several Linker Errors, that i got with version 10 are not seen anymore. Yipeee!!!
But I am still getitng the following Linker Errors, even though this solution compiles fine with MS C++ Compiler,
xilink: executing 'link'
BuildManager.def : error LNK2001: unresolved external symbol DllCanUnloadNow
BuildManager.def : error LNK2001: unresolved external symbol DllGetClassObject
BuildManager.def : error LNK2001: unresolved external symbol DllRegisterServer
BuildManager.def : error LNK2001: unresolved external symbol DllUnregisterServer
Why are these errors coming? Am i missing something here?
Komal
Komal
Quoting - komal_dutta
Komal
Komal
This issue has been submitted to our engineer team to fix. It's not an easy fix.But it's been worked on.
Jennifer
If you turn off the /GL or the /Qipo option, it will build fine.
