When I try to compile the following program with runtime library Multithreaded Debug (/MTd).
#include <thread> #include <iostream> int main() { auto a = std::this_thread::get_id(); std::cout << "a"; }
I get the following errors.
1>libcpmt.lib(ppltasks.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in Source.obj
1>libcpmt.lib(ppltasks.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MT_StaticRelease' doesn't match value 'MTd_StaticDebug' in Source.obj
1>libcpmt.lib(excptptr.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in Source.obj
1>libcpmt.lib(excptptr.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MT_StaticRelease' doesn't match value 'MTd_StaticDebug' in Source.obj
1>libcpmt.lib(thread0.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in Source.obj
1>libcpmt.lib(thread0.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MT_StaticRelease' doesn't match value 'MTd_StaticDebug' in Source.obj
1>c:\...\Projects\Project2\Debug\Project2.exe : fatal error LNK1319: 6 mismatches detected
I use:
- Visual Studio 2015 (Version 14.0.25431.01 Update 3)
- Intel Parallel Studio 2018 Update 4 (2018.5.274)
- Microsoft Windows 10 Pro
- Appart from the runtime library I use the default values from an empty Visual Studio C++ Project.
I cannot possibly understand what the problem could be. Is there something wrong with me, or is there a bug in the compiler or somewhere else?
The error goes away if I remove the second line std::cout... It also goes away if I use printf('..') instead, so it seems to be an issue with the combination of thread and iostream.
I'm able to solve the problem by ignoring that specific library (/NODEFAULTLIB:"libcpmt.lib"), but I would rather like to find the real cause of the problem.
Does anyone have any idea what it could be?
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
I wonder if it compiles with MS compiler?
Viet
(I'm a colleague of Geir)
Yes, it does compile with with MSVC.
I have now tested it from the commandline with the single source file.
$ icl main.cpp # This is ok $ icl main.cpp /MTd /link /NODEFAULTLIB:libcpmt.lib # This is ok $ icl main.cpp /MTd # This causes the error
Using cl (MSVC) instead of icl is no problem.
Is it possible to reproduce or is it a problem just on my system?
It compiles fine with MSVC.
I have now tested the single source file from the command line:
> icl main.cpp # This is ok > icl main.cpp /MTd /link /NODEFAULTLIB:libcpmt.lib # This is ok > cl main.cpp /MTd # This is ok (using cl (MSVC)) > icl main.cpp /MTd # This gives the link errors described in the first post.
So is this reproducible? Or is it something wrong on my system?
I am able to reproduce it and submitted this issue to our developer and will keep you updated. Internal tracker is CMPLRLIBS-2727.
Viet
Thanks for looking into it, Viet.
Good to know it's not our fault. :)
Hello, I was wondering if this issue has been resolved? I'm seeing something similar in a VS2017 project (with Intel Parallel Studio 2018 update 3 for Fortran).
The C++ project's runtime library setting is /MTd (Multi-threaded Debug)
Below are the link errors;
libcpmt.lib(ppltasks.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in COMMap1D.obj
1>libcpmt.lib(ppltasks.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MT_StaticRelease' doesn't match value 'MTd_StaticDebug' in COMMap1D.obj
1>libcpmt.lib(excptptr.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in COMMap1D.obj
1>libcpmt.lib(excptptr.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MT_StaticRelease' doesn't match value 'MTd_StaticDebug' in COMMap1D.obj
Thank you for any assistance.
Tony
As far as I know, it hasn't been fixed in the latest released compiler.
I can reproduce this and I confirmed it hasn't been fixed in the latest version (ICC 19.0 Update 4)
I really hope some dev can take a look into this. It still happening in ICC 19.1 Technical Preview (package 085) and ICC 19.0.5.
With both MSVC 2019 16.4 preview 1 (VC++ 14.24.28117) and the stable MSVC 2019 16.3.1 (VC++ 14.22) [Windows SDK 10.0.18362.0]
