I get the following linking error when building a debug build with Intel 16.0 compiler:
error LNK2019: unresolved external symbol ___intel_ssse3_strncpy referenced in function
Does anyone know the corresponding lib where this symbol resides?
Many thanks,
Andrew.
ps> Using windows with VS2013, Intel Compiler 16.0.
Hello, have you linked with libirc.lib? Probably you use /nodefaultlib option and this lib disapeared from the project.
--Vladimir
Hi all,
Yes, good call. However, this was the first setting I checked. Alas, /NODEFAULTLIB is not being used.
But I did find out which settings seemed to cause this bizarre behavior in DEBUG build only. /FR and possible /Qstd=c99.
Hope this helps the compiler team.
Andrew.
Okay. Found the issue. Somehow, which I'm currently trying to understand, VS2013 is dropping the Intel system library path.
Thanks for all the help.
Andrew
