Hi all,
I have a library which was built using Intel C++ compiler.
I want to link this library to an application in Microsft visual studio. While linking I am getiing following error message. LINK : fatal error LNK1104: cannot open file 'libmmt.lib'.
How can I solve this?? Please help..
Add the "lib" folder to your lib path (should be done with the iclvars.bat file in the intel install folder.)
Thanks for the reply.
But my issue is not solved yet. My library is built using Visual Studio2005(Using ingetated Intel c++ compiler). I want to integrate this libary to an application using Visual Studio 2005(using microsoft compiler and linker, ie whithout using intel C++ compiler). But I am getting following error message.
I dont know , how my application is getting this "libmmt.lib" name. In my library workspace I didn't include any system library directly. Please help.
While buiding library in VS2005(using intl C++compiler), how can I remove the reference to libmmt.lib. In my library code, I am not using any complex math functions.
I am having the same problem. This time building a MATLAB mex file for a library that was built using the Intel compiler. The machine running MATLAB should not have access to the Intel compiler.
Did you find a solution?
