I have installed C++ Compiler 11.1.080 and without problems, but There is not all the libraries in the bin folder and compiler doesn't work. After this It happen the same with fortran.
Do you know anything about it? It's possiblle to work Fedora 17 with this intel compilers.
I am trying to install Intel non-commercial C compiler on Fedora 17. First I installed Intel® C++ Composer XE 2013 for Linux
in the Compilers and Libraries section. It downloads by default the latest update. But while installing I get error message on Step 1 of 7.
Missing optional prerequisites
-- Unsupported OS
The Details says it supports Fedora 18 and 19. So can anyone suggest an appropriate Compiler version?
But under the product suites:
Intel® C++ Studio XE 2013 for Linux
installs absolutely with no error message.
Hence after all this I can't invoke the icc. Can anyone help?
Thanks, PD.
The above issue is still there. With the error as above I completed the installation of the Compiler (Intel® C++ Composer XE 2013 for Linux ).
Then ran the command
source /opt/intel/composer_xe_2013_sp1.3.174/bin/iccvars.sh
Almost followed whatever it is in the link
https://software.intel.com/en-us/articles/using-intelr-compilers-for-linux-under-fedora
But now invoking icc I get the following error message: ld: cannot find -lstdc++
Now I see libstdc++ is installed like invoking the command
ldconfig -p | grep libstdc++ the output is
libstdc++.so.6 (libc6,x86-64) => /lib/libstdc++.so.6
libstdc++.so.6 (libc6,x86-64) => /lib64/libstdc++.so.6
libstdc++.so.5 (libc6,x86-64) => /lib64/libstdc++.so.5
I created symbolic link of libstdc++.so.6 to the folder /usr/lib/, /lib/, /opt/intel/composer_xe_2013_sp1.3.174/bin/
but I get the same compilation error: ld: cannot find -lstdc++
I am still a novice on all this. So can anyone help me out.
The command icpc includes specific references to search libstdc++ (normally, using the paths inherited from the g++ you have active). As icc is a C compiler, it doesn't include C++ library paths by default in its creation of an ld script.
If you built a .c source file using gcc or icc, it wouldn't find STL headers nor use mangling conventions which would enable it to call functions in libstdc++.
The distinction between icc and icpc for the most part mirrors that between gcc and g++.
Thanks Tim. Invoking g++ gave the error message: bash: g++: command not found...
So installing g++ by: yum install gcc-c++
solved my problem. Thanks again. PD.
