Intel® C++ Compiler
List of ICC error codes
Ashwin_D_1
I am using ICC for one of my school projects using the heterogeneous offload programming model. I was wondering if there is a list of error codes that intel provides which I can use for debugging.
Kittur_G_Intel
Hi Ashwin,
Well, the only way you can get a dump of all the errors/codes is by using the -diag-dump switch which will display the currently enabled diagnostic messages to stdout or to a specified diagnostic output file. For some related diagnostics elaboration you may find some KB articles with some explantation on some key diagnostics in the knowledge base which you can try searching for in IDZ( Intel developer zone) at: https://software.intel.com/en-us
_Kittur
Ashwin_D_1
Thanks for this!
Kittur_G_Intel
Pleasure Ashwin, please let me know if you need any other info or clarification on the diagnostics or related to the dumped info as well.
_Kittur
