Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
7747 Discussions
Local variables (F32vec4) show incorrectly in VS2012 debugger
Harald_Deischinger
See the following example code:
[embed]
#include <fvec.h>
int main(int argc, char* argv[])
    F32vec4 a(1.0f);
    int b = 1;
    return 0;
[/embed]
Setting a breakpoint in the b=1 line and watching the value of a only shows garbage in VS2012 when the code is compiled uing Intel compiler.
When the code is compiles using Microsoft compiler, everything is looking fine.
See also attached screenshot.
Any Ideas?
harald
PS: Versions in use:
Microsoft Visual Studio Professions 2013, 11.0.60610.01 Update 3
Intel C++ Composer XE 2013, Package ID: w_ccompxe_2013.0.089
Bernard
Black Belt
What has been highlighted in your screenshot looks like registers context maybe improperly interpreted by VS2012 debugger.
Harald_Deischinger
good news - it seems that this is fixed with SP1.
