Intel® C++ Compiler
7956 Discussions
Looking for a conditional intrinsic SSE command
amoshkov
Im looking for an SSE command that is equivalent to if
The following example:
if( a < b )
a = b;
else
a = c;
is conveniently optimized with:
mask = _mm_cmplt_pd (a, b);
a = _mm_blend_pd (c, b, mask);
In this case:
  1. The comparison is mapped to the first intrinsic operation
  2. The conditional assignment is mapped to the second intrinsic operation
However, in the next example (without an else)
if( a < b )
a = b;
If the condition isnt met, the regular C code skips the assignment operation,
But with the following optimized code:
a = _mm_blend_pd (a, b, mask);
the assignment still happens.
My question:
Is there a way to save the assignment if not needed (i.e. if the conditioned isnt met)?
Thomas_W_Intel
You can only avoid the blend instruction if the condition is false for both comparisons that _mm_cmplt_pd does. Furthermore, you will need (at least) 1 cycle for a conditional jump and _mm_blend_pd needs only1 cycle. This looks already optimal to me.
Kind regards
Thomas
TimP
The blend with unconditional store is probably optimum, for cases where branch prediction isn't effective. So, the answer to that question is dependent on context, and may require actual testing.
amoshkov
MAD willhal:
Is the avoidance done automatically if the condition is false for both comparisons?
amoshkov
tim18:
Can you explain what you mean by blend with unconditional store? are you referring to a case where the condition is true for one of the masks? Also, what do you mean by is probably optimum?
amoshkov
MAD willhal:
Is there a reference that specifies the number of cycles that each of the _mm operations require? (or do they all require one cycle?)
TimP
stores a, regardless of whether the value changes. This avoids any dependence on branch prediction, but could increase latency, compared to compilation with a predictable branch and frequent skipping of the store.
Thomas_W_Intel
No, it is not avoided. However, avoiding it does not make sense. The blend instruction needs only 1 single clock cycle--regardless of how many values are copied (0, 1, or 2). You can hardly do better than that.
If you introduced some additional code to skip the blend, it will need at least oneinstruction for the jump. Plus, the branch prediction might be wrong, which will result in additional wasted cycles.
With an out-of-order engine, it is very difficult to predict if some piece of code is optimal---but in this case it is very likely :)
The latency and throughput of instructions can be found in Appendix C of the "Intel and IA-32 Architectures Optimization Reference Manual" (http://www.intel.com/design/processor/manuals/248966.pdf)
Kind regards
Thomas
