Intel® C++ Compiler
7956 Discussions
MATRIX MULTIPLICATION USING SSE
Smart_Lubobya
can some one show me how to do a two 4x4 matrix multiplication using SSE instruction. codes should be compatible with c++ compiler
TimP
Quoting - Smart Lubobya
http://cache-www.intel.com/cd/00/00/29/37/293749_293749.pdf
includes such a description.
Another way would be to use the SSE transpose code you can find by the search button above, and then it may be possible to persuade the compiler to optimize the rest:
temp[][] = transpose(a[][])
for()
for()
c = inner_product(temp[...],b[...],0.f)
possibly by writing out the 4 inner_product instances each with declared aligned(16) vectors.
Smart_Lubobya
Quoting - tim18
for()
for()
Smart_Lubobya
i have ready the pdf quoted but can not still understand how SSE are used. more light please
hydroxyprolin
SSE instructions can be executed by using SIMD intrinsics or inline assembly.
This application note describes the multiplication of two matrices using Streaming SIMD Extensions:
AP-929 Streaming SIMD Extensions - Matrix Multiplication
In Section 4.3 you can find a ready-to-run example for 4x4 matrix multiplication.
TimP
Quoting - hydroxyprolin
Not to mention by writing standard Fortran, or nearly standard C or C++ code, and using one of the usual compilers. Schematically:
[cpp]#include
#include
#include
#include
#include
using namespace std;
void mm44(float **a,float **b,float **c){
__declspec(align(16)) float at[4][4],bl[4][4];
for(int j=0; j<4; ++j)
for(int i=0; i<4; ++i){
at = a; //transpose 1st operand
bl = b; //local aligned non aliased
for (int j = 0; j < 4; ++j) //return matrix multiply 4x4
for (int i=0; i < 4; ++i)
c = inner_product(&at[0],&at[4],&bl[0],0.f);
}[/cpp]
Unfortunately, the vector code generated by ICL is dead, as it has minimum count of 8.
jeff_keasler
There's some code at the bottom of this pdf for general matrix-matrix multiplication via inline intrinsics:
http://people.redhat.com/drepper/cpumemory.pdf
Great paper.
Smart_Lubobya
can someone advice the best compiler that i can buy for c++ and SSE use
send quotes to my email : cslubobya@yahoo.com
