Intel® C++ Compiler
7952 Discussions
MPI compilation problems with mpicc.bat and mpifc.bat
Ian_Chivers
I've found some issues with the batch files
mpicc.bat
and
mpifc.bat
when trying to compile a C++ mpi program.
the batch files contain
echo.
statements which are illegal on windows.
I've had this issue in the past with mpi Fortran code, but not C++ code.
Ian
Ian_Chivers
I've installed the latest release and the problem no longer happens.
ShivaniK_Intel
Thanks for posting in the Intel forums.
>>> "I've found some issues with the batch files"
Could you please elaborate more on this issue?
Could you please let us know the version of Intel MPI you have been using?
>>>" when trying to compile a C++ mpi program"
Could you please provide us with the sample reproducer and steps to reproduce the issue at our end?
Thanks & Regards
Shivani
Ian_Chivers
Here are the outputs from the various
batch files that Intel provide.
C:\document\cpp\examples>mpicc ch3705.cxx
mpicc.bat for the Intel(R) MPI Library 2021.7 for Windows*
Copyright Intel Corporation.
'echo.' is not recognized as an internal or external command,
operable program or batch file.
C:\document\cpp\examples>mpicl ch3705.cxx
C:\document\cpp\examples>mpicxx ch3705.cxx
C:\document\cpp\examples>mpifc ch3705.cxx
mpifc.bat for the Intel(R) MPI Library 2021.7 for Windows*
C:\document\cpp\examples>mpiicc ch3705.cxx
C:\document\cpp\examples>mpiicpc ch3705.cxx
Here is the source code
#include <chrono>
#include <cmath>
using namespace std;
class timer
public:
timer() : start_timing(hi_res_clock::now()) {}
void reset()
start_timing = hi_res_clock::now();
double elapsed() const
return(std::chrono::duration_cast<second_>
(hi_res_clock::now() - start_timing).count());
private:
typedef std::chrono::high_resolution_clock hi_res_clock;
typedef std::chrono::duration<double, std::ratio<1> > second_;
std::chrono::time_point<hi_res_clock> start_timing;
#include <iostream>
#include <cassert>
#include <chrono>
#include <string>
#include <cstdlib>
#include <mpi.h>
void print_time(const string& heading, const double& t)
cout << heading << " : ";
cout.width(10);cout.precision(6);
cout.setf(ios::right);
cout.setf(ios::showpoint);
cout.setf(ios::fixed);
cout << t << endl;
void format_20_16()
cout.width(20);cout.precision(16);
void format_08_06()
cout.width(8);cout.precision(6);
double f(double x)
double f;
f = 4.0 / (1.0 + x * x);
return(f);
int main()
timer timer_01;
timer timer_02;
double t;
string heading;
double cplusplus_internal_pi;
double interval_width;
double partial_pi;
double partial_sum;
double total_pi;
double x;
double time_difference;
double* sendbuf;
double* recbuf;
int i;
int j;
int n_intervals;
int error_number;
int this_process;
int n_processes;
MPI_Init(NULL, NULL);
MPI_Comm_size(MPI_COMM_WORLD, &n_processes);
MPI_Comm_rank(MPI_COMM_WORLD, &this_process);
heading = "\n Program starts ";
if (this_process == 0)
t = timer_01.elapsed();
print_time(heading, t);
n_intervals = 1000000;
cplusplus_internal_pi = 4.0 * atan(1.0);
cout << "\n C++ internal pi 4.0*atan(1.0) \n" << endl;
cout << " ";
format_20_16();
cout << cplusplus_internal_pi << endl;
heading = " Loop time ";
for (j = 1; j < 5; j++)
interval_width = 1.0 / n_intervals;
partial_sum = 0.0;
for (i = this_process +1 ; i <= n_intervals; i = i + n_processes)
x = interval_width * (double(i) - 0.5);
partial_sum = partial_sum + f(x);
partial_pi = interval_width * partial_sum;
sendbuf = &partial_pi;
recbuf = &total_pi;
MPI_Reduce(sendbuf,
recbuf,
1,
MPI_DOUBLE,
MPI_SUM,
0,
MPI_COMM_WORLD);
time_difference = t;
timer_01.reset();
cout << " ";
cout << " N intervals ";
cout.width(12);
cout << n_intervals;
cout << " time = ";
format_08_06();
cout << time_difference << endl;
cout << " Calculated ";
format_20_16();
cout << total_pi << endl;
cout << " Difference ";
format_20_16();
cout << abs(total_pi - cplusplus_internal_pi) << endl;
n_intervals = n_intervals * 10;
t = timer_02.elapsed();
heading = " \n Total time ";
MPI_Finalize();
return(0);
I did a dir/s mpi*.bat and this is the output
Volume in drive C is OS
Volume Serial Number is 50BD-6CC8
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\2021.7.1\bin
21/10/2022 17:40 21,398 mpicc.bat
21/10/2022 17:40 1,036 mpicl.bat
21/10/2022 17:40 1,078 mpicxx.bat
21/10/2022 17:40 979 mpif77.bat
21/10/2022 17:40 979 mpif90.bat
21/10/2022 17:40 25,765 mpifc.bat
21/10/2022 17:40 1,033 mpiicc.bat
21/10/2022 17:40 1,037 mpiicpc.bat
21/10/2022 17:40 981 mpiifort.bat
21/10/2022 17:40 673 mpitune.bat
10 File(s) 54,959 bytes
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\2021.7.1\etc\conda\activate.d
21/10/2022 16:35 1,396 mpivars.activate.bat
1 File(s) 1,396 bytes
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\2021.7.1\etc\conda\deactivate.d
21/10/2022 16:35 1,990 mpivars.deactivate.bat
1 File(s) 1,990 bytes
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\latest\bin
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\latest\etc\conda\activate.d
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\latest\etc\conda\deactivate.d
Total Files Listed:
24 File(s) 116,690 bytes
0 Dir(s) 458,762,018,816 bytes free
I did a grep on the above batch files looking for "^echo"
and found that mpicc.bat and mpifc.bat both contains
echo.
statements.
Hope this helps
Ian
ShivaniK_Intel
We are unable to reproduce the error at our end with Intel MPI 2021.7 version.
Please refer to the below for the output details.
C:\Users\karangux\Desktop>mpicc shivani.cpp
Microsoft (R) C/C++ Optimizing Compiler Version 19.30.30705 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
shivani.cpp
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Tools\MSVC\14.30.30705\include\ostream(410): warning C4530: C++ exception handler used, but unwind semantics are not enabled. Specify /EHsc
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Tools\MSVC\14.30.30705\include\ostream(403): note: while compiling class template member function 'std::basic_ostream<char,std::char_traits<char>> &std::basic_ostream<char,std::char_traits<char>>::operator <<(double)'
shivani.cpp(42): note: see reference to function template instantiation 'std::basic_ostream<char,std::char_traits<char>> &std::basic_ostream<char,std::char_traits<char>>::operator <<(double)' being compiled
shivani.cpp(37): note: see reference to class template instantiation 'std::basic_ostream<char,std::char_traits<char>>' being compiled
Microsoft (R) Incremental Linker Version 14.30.30705.0
/out:shivani.exe
"/LIBPATH:C:\Program Files (x86)\intel\oneAPI\mpi\latest\env\..\lib\release"
"/LIBPATH:C:\Program Files (x86)\intel\oneAPI\mpi\latest\env\..\lib"
impi.lib
shivani.obj
C:\Users\karangux\Desktop>shivani.exe
 Program starts :  0.229034
  3.1415926535897931
 N intervals   1000000 time = 0.261210
 Calculated  3.1415926535897643
 Difference  0.0000000000000289
 N intervals   10000000 time = 0.167000
 Calculated  3.1415926535897309
 Difference  0.0000000000000622
 N intervals  100000000 time = 1.671505
 Calculated  3.1415926535904264
 Difference  0.0000000000006333
 N intervals  1000000000 time = 16.126087
 Calculated  3.1415926535899708
 Difference  0.0000000000001776
 Total time : 18.236686
Could you please let us know if you further have any issues?
Thanks & Regards
Shivani
ShivaniK_Intel
As we didn't hear back from you, could you please let us know if you further have any issues?
Thanks & Regards
Shivani
Ian_Chivers
ShivaniK_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
